    Thành viên danh dự TuấnPhát_GSM's Avatar
    Jan 2009
    Mặc định How to Enter Unlock Codes on LG phones.
    Below you can find information how to input unlock codes to LG phones. It`s randomly written, so perform CTRL-F to search by models or use scroll. If you have instructions for some models missed here please add it to this thread.
    For the following models you must insert an accepted SIM Card and then:
    LG C3100 press 2945#*3101#
    LG C3380 press 2945#*7101#
    LG F2300 press 2945#*7101#
    LG KE260 press 2945#*2601#
    LG KE970 press 2945#*9701#
    LG KF245c press 2945#*7101#
    LG KF390 and KF390q *#865625#
    LG KF600 press 2945#*71001#
    LG KF755d press 2945#*755# (you need to insert a not-allowed SIM card instead and then enter the sequence to enter the code)
    LG KG120 press 2945#*1201#
    LG KG220 press 2945#*1201#
    LG KG240 press 2945#*3311#
    LG KG280 press 2945#*7101#
    LG KG290 press 2945#*7101#
    LG KG800 press 2945#*7101#
    LG KP210a press 2945#*71001# ( (you need to insert a not-allowed SIM card instead and then enter the sequence to enter the code)
    LG KP500 press 2945#*71101# LG KP265 press 2945#*265#
    LG KU250 press 2945#*250#
    LG KU380 press 2945#*380#
    LG TE365 press 2945#*365# (you need to insert a not-allowed SIM card instead and then enter the sequence to enter the code)
    Next, a secret menu will appear, go to settings-security-sim lock, enter NCK and press OK.
    For the following models you must insert a not-allowed SIM and then:
    LG KU311 press 815118#*#
    LG KU800 press 82652#*#
    LG L600v press 815118#*#
    LG U8150 press 277634#*#
    LG U8210 press 277634#*#
    LG U8500 press 277634#*#
    LG U400 press 2945#*88110#
    LG KC550 press 2945#*71001#
    LG KU580 press 2945#*580#
    LG KT520 press 2945#*520#
    LG KF750 press 2945#*750#
    LG KG275 press 2945#*20001#
    LG KS360 press 2945#*71001#
    LG KS500 press 2945#*500#
    LG KP270 press 2945#*270#
    LG KF240 press 2945#*240# or 2945#*2401#
    Enter NCK and press OK.
    How to Enter Unlock Codes on all other LG cell phones:
    1. Switch ON your phone with an allowed SIM card
    2. Then compose:
    3. 2945#*5101# - (if you have a LG 510w)
    4. 1945#*5101# - (if you have a LG 1200 & B1200)
    5. 2945#*5221# - (if you have a LG 5200 & 52200)
    6. 2945#*5301# - (if you have a LG 5300)
    7. 2945#*5401# - (if you have a LG 5400)
    8. 2945#*70001# - (if you have a LG 7020)
    9. 2945#*7101# - (if you have a LG 7100)
    10. 2945#*1201# or 2945#*70001# - (if you have a LG 1100 or 1150)
    11. 2945#*70001# - (if you have a LG7250T)
    12. 2945#*2201# - (if you have a LG C2200)
    13. 2945#*5301# - (if you have a LG T5100)
    14. 2945#*3311# - (if you have a LG C3310)
    15. Go to "Menu" and then to "Settings"
    16. Then select "Security"
    17. To finish select "Network Provider" and select "Deactivate"
    18. Enter the unlock code.
    Jan 2009
    How to Enter Unlock Codes on LG KB770:
    Insert an original simcard and turn phone on
    Enter sim PIN if required
    Enter 2945*#770#
    From the menu that pops up select "SIM unlock"
    Enter unlock code you received and press OK
    The phone will then reboot and the unlock is complete
    How to enter Unlock Codes to LG GB250 & GB220
    Power on your phone without SIM card
    Enter 2945#*505#
    Enter unlock code and press OK
    How to Enter Unlock Codes on LG GT505:
    Enter 2945#*505#
    How to Enter Unlock Codes on LG KP100:
    1) Insert a not allowed SIM card
    2) Press the unlock button
    3) Enter the code
    OR
    1. Insert allowed SIM.
    2. Booting (Request PIN Code, PIN Code enable)
    3. In Idle Screen, Input the hidden number (2945#*20001#)
    4. Input the number (above), go back to the idle screen
    5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate:
    6. Select “1.Deactivate:” Menu, Display pop up “ SIM Lock Code:”.
    7. Input right Unlock code, Display pop up “Deactivate". 8. Reboot, and unlock simlock code
    How to Enter Unlock Codes on LG KF390 and KF390q:
    1) Insert a SIM Card from the network the mobile is locked to and turn it on
    2) Insert the following sequence *#865625#;
    3) Select 'Unlock USIM'
    4) Select 'Network Lock'
    5) Insert the unlock code
    6) Reinsert the unlock code
    7) Select OK. Done!
    How to Enter Unlock Codes on LG Prada (e.g KE850, etc):
    1. Switch the telephone on with Original SIM card inside.
    2. Enter SIM pin if required.
    3. Enter 2945#*8501# and press the call button (middle button bottom of the screen).
    4. SIM unlock mode will appear on screen.
    5. Enter unlock code
    6. Select Reboot.
    7. Switch phone off, and then turn back on again. Phone is now unlocked
    How to Enter Unlock Codes on LG KE990 / KU990 Viewty:
    1. Insert original sim card and turn phone on.
    2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990#
    3. A menu will pop up, select sim unlock:
    4. Another menu will appear, select Network lock. Enter your unlock code and press ok
    5. The phone will then reboot and the unlock is complete.
    How to Enter Unlock Codes on LG KG245 (Vodafone Australia):
    1. Insert a Vodafone Australia working SIM card.
    2. Ensure the phone is charged and then switch the phone on.
    3. Optional Step: If the SIM card has a PIN, enter your PIN number
    4. Wait for the phone to power up then enter 2945#*7101#
    5. Select Menu , then go to Settings > Security > SIM Lock > Network
    6. Select Deactivate and enter the 8-digit unlocking code provide for your handset.
    7. The handset will be unlocked automatically and will display “Done”. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
    How to Enter Unlock Codes on LG KG800 or TG800 Chocolate:
    1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
    2. Go to: Settings>Security>SimLock>Network
    3. Select deactivate. Enter the unlock code
    How to Enter Unlock Codes on LG C2000:
    1. Insert non-Cingular SIM card
    2. Power on the handset - phone will display "phone restricted"
    3. Select "Cancel" - phone will display "phone restriction code"
    4. Enter the SIM Unlock code
    5. Select "OK" - the handset is now successfully unlocked
    How to Enter Unlock Codes on LG U8150:
    1. Switch ON your phone with a not allowed SIM card.
    2. Compose: 277634#*#.
    3. Go to menu "SIM Lock".
    4. Enter the unlock code
    How to Enter Unlock Codes on LG INCITE CT810
    Power on phone with original SIM card
    Type 2945#*810#
    In the menu that appears select Sim unlock
    Enter supplied unlock code
    Your phone is unlocked
    How to Enter Unlock Codes on LG F2250
    Power on phone with Orange SIM card inserted
    While in the Start menu type 2945#*3311#
    Return to the startup screen
    Press Menu key
    Select Settings > Security > Sim Lock > Network > Deactivate
    How to Enter Unlock Codes on LG KF700 aka LG VIRGO
    Power on phone with an original (from the locked carrier) SIM card inserted
    Type 2945#*700#
    A menu will pop up. Select "Sim unlock"
    Enter supplied unlock code and press "OK"
    Your phone is now unlocked
    How to Enter Unlock Codes on LG U8110:
    1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
    2. Select 'Sim Unlock' menu #
    3. Enter NCK code, then validate
    4. Your phone is now unlocked.
    How to Enter Unlock Codes on LG U8150, other UMTS models
    Power on phone with a non-original SIM card inserted
    Type 277634#*#
    How to Enter Unlock Codes on LG U8210:
    1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
    2. Shows test menu
    3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
    4. Handset shows 'Enter NCK'
    5. Enter code and then hit OK.
    How to Enter Unlock Codes on LG U81xx:
    1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2. Enter the code
    In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
    How to Enter Unlock Codes on LG CU720, TU720, other SHINE series
    Type *#865625#CODE where CODE is the unlock code provided by LGTooL
    Select "OK"
    If this didn't work you can also try to repeat the above steps with a non-original SIM card inserted
    How to Enter Unlock Codes on LG CE110
    Prior to unlocking reset the phone to "Factory Default"
    Power on phone with a non-accepted SIM card
    Select "Cancel" - phone will displays "Phone restriction code"
    Select "OK"
    How to Enter Unlock Codes on LG CE500
    Power on phone with Cingular SIM card
    Type 2945#*7101#
    How to Enter Unlock Codes on LG KG275
    Power on phone with non original SIM card
    Type in the code you received from LGTooL.com
    Press "Send" key
    If this didn't work append #*# to the end of the entered code
    How to Enter Unlock Codes on Cingular AT&T LG CU575 TRAX:
    1. Insert non-Cingular SIM card.
    2. Power on the handset. Phone will display "Invalid SmartChip"
    3. Now enter *#865625# then select option 1 and then again select 1 and enter your code
    How to Enter Unlock Codes on LG CU400, CU500 Cingular AT&T
    If the phone doesn't display "Invalid SmartChip" power off and on, then try again
    Type 159753#*#
    Select "1 Unlock USIM", then "1 network lock"
    Phone will display "Enter NCK, Remaining 5"
    Enter the 8 digit unlock code
    Select "OK"
    How to Enter Unlock Codes on LG CU575, CU515 Trax Cingular AT&T
    Type *#865625#
    Select option 1 and then again select 1
    Enter the supplied unlock code
    5) Select "OK" - the handset is now successfully unlocked
    Jan 2009
    How to Enter Unlock Codes on LG U400 Shine (2 codes needed):
    1. Insert the network SIM in the handset which works with the phone (from the lockedcarrier).
    2. Enter 2945#*9636#.
    3. The phone will then prompt 'Unlock sim'. Press OK.
    4. The phone will then prompt 'Network Unlock'. Press OK.
    5. The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code, Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. If you received a 16 digit code, enter it. The phone will have space for it.
    6. It should give you the message: Success.
    7. Come back to the main screen and Enter 2945#*9636#.
    8. The phone will then prompt unlock sim. Press OK. 9. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code.
    LG U400
    Type 2945#*9636#
    The phone will then prompt "Unlock sim". Press "OK"
    The phone will then prompt "Network Unlock". Press "OK"
    Enter the 8 digit unlocking code. Press OK.
    he phone will give you message "Succeess"
    Go back to the main screen and enter 2945#*88110#
    The phone will then prompt "Network Unlock/Lock" but if you scroll down you will see a message Enter SP Lock. Enter SP Code
    Then press "OK"
    How to Enter Unlock Codes on LG KE970 Shine:
    4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete.
    OR
    2. Then compose: 2945#*9701#
    3. Press CALL.
    4. It should you ask you for the code
    How to Enter Unlock Codes on LG TU720 Shine
    1. Put in a non-allowed SIM, phone says invalid SIM card (or insert original SIM and proceed to step 2)
    2. Now enter *#865625# then enter your 16 digits code
    OR
    1. Insert the original network SIM
    2. Enter 2945#*88110#.
    3. The phone will then prompt ' Unlock sim'. Press OK.
    5. The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code. Press OK.
    6. If the unlock ing code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code.
    7. It should give you the message Success.
    8. Come back to the main screen and Enter 2945#*88110#.
    9. The phone will then prompt unlock sim. Press OK.
    10. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code.
    11. Then press OK.
    How to Enter Unlock Codes on LG BL40
    Enter 2945#*40#
    Enter unlock code you received from LGTooL and press OK
    How to Enter Unlock Codes on LG BL20
    Enter 2945#*20#
    How to Enter Unlock Codes on LG GW520, GB250
    Insert an original simcard and turn phone on (code can also be entered without SIM card)
    Enter 2945#*71001#
    How to Enter Unlock Codes on LG Viewty GW300
    Enter 2945#*700#
    How to Enter Unlock Codes on LG G910
    Insert a non original simcard and turn phone on
    Select "Emergency mode"
    Enter 2945#*71001#
    Sim unlock mode pop up
    Select Netlock
    How to Enter Unlock Codes on LG KC910, KF910
    Enter 2945#*910#
    Enter unlock code you received from LGTooL and select Reboot
    How to Enter Unlock Codes for KE850, ME850
    6. Select Reboot.
    How to Enter Unlock Codes on LG WATCHPHONE GD810 and GD330
    Insert PIN
    Phone says "Invalid sim card"
    Select "Emergency calls"
    Enter 2945#*71001#
    Select netlock
    Enter your 16-digit unlock code and press ok
    How to Enter Unlock Codes on LG Invision CB630
    Power on phone with a original AT&T SIM card inserted
    Type *#865625# in the phone menu
    Press "Call"
    How to Enter Unlock Codes on LG CU915
    Power on phone with a original SIM card inserted
    Press "OK"
    How to Enter Unlock Codes on LG KF750 aka LG SECRET
    Type 2945#*750#
    How to Enter Unlock Codes on LG GC900, GT360, GT810, KC550, KM500, KM900, KP230, KP270, KP500, KP501, KS360,
    Type 2945#*71001#
    How to Enter Unlock Codes on LG KS360 aka QWERTY
    Type 2945#*71001#
    How to Enter Unlock Codes on LG KF755
    Type 2945#*755#
    How to Enter Unlock Codes on LG KF600
    Type 2945#*600#
    How to Enter Unlock Codes on LG KS20
    Type 2945#*20# and 2945#*990#
    How to Enter Unlock Codes on LG KG800 CHOCOLATE, TG800 CHOCOLATE
    Insert an original (from the locked carrier) SIM card and power on the phone
    While in standby enter 2945#*5301#. This will activate the extra menu
    Select "Settings" -> "Security" -> "Sim lock" -> "Network"
    Select "Deactivate"
    How to Enter Unlock Codes on LG G7020
    Type 2945#*70001#
    Select "Security"
    Select "Network Provider" and then "Deactivate"
    How to Enter Unlock Codes on U880
    Use this code with non-accepted sim card: 277634#*#
    The Test Mode menu will display.
    Select SIM test menu
    Type 2945#*#
    Select SIM Unlock menu
    Phone will display "Enter NCK"
    Enter your NCK and OK
    If above given dont work .........
    Insert the accepted network SIM in the handset
    Enter 2945#*9636#.
    Jan 2009
    How to Enter Unlock Codes on LG T5100
    Type 2945#*5301#
    Select "Security"
    How to Enter Unlock Codes on LG C2200
    Type 2945#*2201#
    Select "Security"
    How to Enter Unlock Codes for LG GM360 Viewty Snap
    1. Power on your LG Viewty GM360 with the original SIM card in.
    2. Enter 2945#*360#
    3. A menu will pop up, select SIM Unlock.
    4. Enter your unlock code and hit OK.
    How to Enter Unlock Codes for LG GS290 Cookie Fresh
    1. Power phone ON with original SIM
    2. Type 2945#*290# to enter unlock menu
    3. Enter the unlocking code
    How to Enter Unlock Codes for Optimus One P500
    1. Switch the phone with no sim card inserted.
    2. Dial 2945#*500# to enter unlock menu
    How to Enter Unlock Codes for LG GT400
    1. Turn phone on without simcard
    3. Enter 2945#*400#
    4. A menu will pop up, select network unlock
    5. Enter your unlock code and press ok
    6. The phone will then reboot and the unlock is complete
    How to Enter Unlock Codes for LG GT450
    3. Enter 2945#*450#
    How to Enter Unlock Codes for LG GT540
    3. Enter 2945#*540#
    How to Enter Unlock Codes for LG GW620
    1. power phone ON with original SIM
    2. type 2945#*620# to enter unlock menu
    How to Enter Unlock Codes for LG GM205
    1. switch on your phone with original working simcard
    2. enter code 2495#71001# .. nothing will show in the screen.
    3. now go to menu > setting > security > simlock > network lock > deactivate: enter your unlock code in it
    How to Enter Unlock Codes for LG GW820 eXpo
    1. Power on your LG GW820 eXpo with the original SIM card in.
    2. Enter 2945#*700#
    5. Your LG GW820 eXpo may automatically reboot.
    2. Type 2945#*71001# to enter unlock menu
    How to Enter Unlock Codes for LG GB250, GB220
    1. Power on your phone without SIM card
    2. Enter 2945#*71001#
    3. From the menu that pops up select "SIM unlock"
    4. Enter unlock code you received from us and press OK
    How to Enter Unlock Codes for LG C1100
    - First you must put in an allowed simcard, then :
    - type 2945#*1201#.
    - Goto Menu/Settings/Security Settings/Sim Locks
    - Select 'Locktype'/Deactivate and Enter the code.
    How to Enter Unlock Codes for LG KP170
    1 - Switch ON your phone with a T Mobile Sim inserted
    2 - Press telephone icon at bottom of screen to bring up the phone keypad
    3 - Then compose : 2945#*170#
    4 - A menu will pop up, select Unlock Usim
    5 - Then Select Network Lock
    6 - Enter your unlock code and press ok (you only have 10 attempts)
    7 - The phone will then reboot and the unlock is complete.
    How to Enter Unlock Codes for LG TE365
    1. Power on phone with original SIM card
    2. Type *#0001#code#
    3. Your phone is unlocked
    How to Enter Unlock Codes for LG CB630 (Invision)
    1) Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
    2) Dial this into the LG Incite's phone menu
    3) *#865625#
    4) Press CALL.
    5) It should you ask you for the code.
    How to Enter Unlock Codes for LG U830
    1. Have your unlock code handy.
    2. InserI a 3 SIM card in the phone and switch power on.
    3. Enter the following key sequence 94471877#*#
    4. Select the option ‘unlock USIM’.
    5. Select the option ‘network unlock’
    6. Enter your unlock code.
    7. Handset should now display ‘network unlock success’.
    8. Handset will now restart.
    How to Enter Unlock Codes for LG KF300
    1. Put wrong simcard
    2. Phone alert 'insert correct card'
    3. Right under in screen you see deblokkeren (dutch)
    4. Click on it en click 'Network lock off'
    5. Insert code!
    How to Enter Unlock Codes for LG KF755d
    3. Enter 2945#*755# (or 2945#*750# if 1st option doesn't work)
    4. A menu will pop up, select sim unlock
    How to Enter Unlock Codes for LG Incite CT-810
    - Insert a SIM from the original network
    - 2945#*810# will show the unlock menu
    - Enter unlock code
    How to Enter Unlock Codes for LG KP265
    1 - Use Original SIM to switch ON the Phone.
    2 - Compose 2945#*265#
    3 - Then go to MENU > SETTINGS > SECURITY
    4 - Then go to SIM LOCKS > NETWORK > DESACTIVATE
    5 - ENTER NCK (your Unlock Code)
    How to Enter Unlock Codes for LG ME550
    2 - Compose 2945#*71101#.
    3 - Menu will appear, go to settings > security > sim lock
    4 - Enter NCK ( Unlock Code ) and press OK.
    How to Enter Unlock Codes for LG TU915
    - Switch ON your phone with an allowed SIM Card
    - Then compose: 2945#*9701#
    - It should you ask you for the code.
    OR
    - Enter *#865625# then enter your 16 digits code.
    Jan 2009
    How to Enter Unlock Codes for LG VU CU915 & CU920 (Vu)
    1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM
    2. Enter *#865625# then the 16 digit unlock code
    3. Device should say: Network Lock Deactivated
    4. Phone may automatically reboot and is now unlocked !
    How to Enter Unlock Codes for LG iQ
    1 - Switch ON mobile with a not Allowed SIM Card,
    2 - If phone ask, enter the PIN code of your SIM Card
    3 - Now phone will ask you to enter the unlocking code !
    How to Enter Unlock Codes for LG U310
    1. Turn ON the phone without SIM Card :
    2. Enter 815118#*#
    3. Sim unlock mode pop up .
    How to Enter Unlock Codes for LG KC550, KS360, KP230, KP500, KP501, KP270, KM900, KM500, GT810, GC900, GT360
    How to Enter Unlock Codes for LG KF700 (aka LG Virgo)
    1. insert original sim card and turn phone on.
    2. Enter 2945#*700#
    How to Enter Unlock Codes for LG KC910, KF910 (aka LG *****)
    2. Enter 2945#*910#
    How to Enter Unlock Codes for LG KF750
    2. Enter 2945#*750#
    How to Enter Unlock Codes for LG KF600
    How to Enter Unlock Codes for LG U970
    2. Enter 2945#*970#
    3. A menu will pop up, select Unlock Usim.
    4. Select Network Lock.
    5. Enter the unlock code and ok.
    How to Enter Unlock Codes for LG U300
    1 - Switch ON the phone with Accepted SIM Card (from Original Network Provider)
    2 - Enter Code : 815118#*#
    3 - then phone will ask to enter NCK
    How to Enter Unlock Codes for LG KU990 Viewty & KE990
    3. Enter 2945#*990#
    6. The phone will then reboot and the unlock is complete.
    or
    1. Without sim phone power "ON"
    2. Hold "camera" + "lock" button
    3. You will get key pad write 2945#*990#.
    4. Press active code.
    5. Your cellphone will be restart
    6. Turn off cellphone and insert your sim (internation sim)
    7. Enjoy your unlocked phone !
    How to Enter Unlock Codes for LG TU720 - LG CU720 (Shine)
    1) Power ON your phone with not allowed sim card (one that didn't come with the phone)
    2) Type *#865625#
    3) the phone will ask you to input the unlock code twice, just input the unlock code
    4) Device is now unlocked
    How to Enter Unlock Codes for LG CE110
    1) Put a non AT&T or Cingular SIM in the phone;
    2) The phone display: Invalid Smart Chip
    3) Power on handset
    4) Select "Cancel" - phone displays "phone restriction code"
    5) Enter the unlock code (8 digit code*)
    6) Select "OK’" - the handset is successfully unlocked
    How to Enter Unlock Codes for LG GR500 (Xenon)
    1) Insert not-allowed SIM card
    2) Power on the handset- phone will display "phone restricted"
    3) Select "Cancel" - phone will display "phone restriction code"
    4) Enter the SIM unlock code
    or
    2. Enter 2945#*9701#
    or
    After turning on your mobile phone, press: *#865625#
    Press Yes to continue.
    Enter the 16 digit Subsidy Unlock Code
    Enter the 16 digit Subsidy Unlock Code, again.
    Device should say: “Network Lock Deactivated”
    How to Enter Unlock Codes for LG CU320
    1) Power on the handset
    2) In Idle screen, input the special code "277634#*#".
    3) Enter the SIM Unlock code
    4) Access the submenu "SIM Test" in Phone Test Mode.
    5) Input the special code "2945#*#".
    6) Access the submenu "SIM Unlock" which is just activated after the special code.
    7) Input the 8-digit Unlock code in the "Enter unlock code" input screen.
    8) It will be unlocked.
    How to Enter Unlock Codes for LG CU400 & CU405
    1) Insert non-Cingular SIM card"
    2) Power on the handset - Phone will display "Invalid SmartChip".
    3) Enter 159753#*#
    4) Enter the 8 digit SIM Unlock code
    5) Select "OK".
    6) The handset will be unlocked.
    How to Enter Unlock Codes for LG CU500
    1) Insert non-Cingular SIM card.
    2) Power on the handset. Phone will display "Invalid SmartChip"
    3) (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
    4) In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
    5) Enter the 8 digit SIM unlock code
    6) Select "OK"
    7) The handset is now successfully unlocked.
    How to Enter Unlock Codes for LG CU515, CU575 (Trax)
    1) Put a non-Cingular sim in the phone
    2) Phone says invalid smart chip
    3) Now enter *#865625# then select option 1 and then again select 1
    4) Enter your 16 digits code
    5) Device should say: Network Lock Deactivated
    6) The handset is unlocked.
    How to Unlock LG (other models not listed in the above guide):
    1. Insert not-allowed SIM card
    2. Power on the handset- phone will display "phone restricted"
    4. Enter the SIM unlock code
  6. ( TuấnPhát_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hungmobile_0947100616 (31-03-2012)
  1. Trả lời: 2
    Bài viết cuối: 24-05-2014, 19:31
  2. Pegasus Box v1.3.4 - unlock codes reading added for some phones with new security
    Bài viết cuối: 19-03-2013, 22:29
  3. Cyclone BOMB - Read UNLOCK Codes for Lumia, No TP, No BF, No Patch, Perm Unlock !!!
    Bài viết cuối: 11-12-2012, 08:47
  4. l7c enter unlock code
    By cochunho in forum P2K Series
    Bài viết cuối: 27-12-2009, 20:22
  5. v3 enter unlock code
    By mobididong in forum MOTOROLA
    Bài viết cuối: 23-10-2006, 17:10
