mình Góp ý tí nhé![]()
C975 (fw … 91i) unlock ok
Connect powered ON handset to PC via Smart-Clip (phone > USB cable > Smart-Clip > LPT cable > PC).
Connect S-Card to PC USB port.
Connect power supply to Smart-Clip and power on the handset.
Launch SmartMoto.
Choose "Smart-Clip USB port" in phone connection window.
Press "Search". Software should perform the following steps:
SmartMoto detects S-Card;
SmartMoto detects Smart-Clip;
SmartMoto detects the handset and reads all information.
The next steps depend on the phone boot version. Follow the instructions in the schedule, please.
Boot 6.36
Boot 6.31
Boot 5.F1/ 6.10/ 6.12
Log to bookmark "Prepare".
Select the appropriate model from SmartMoto list. Make sure that phone model and boot version of the phone to be unlocked exactly match the model and boot version stated in the list.
Press "Prepare" button.
The prepare cycle starts. SmartMoto creates a Temporary Backup File from the handset firmware.
At this time popup window appears at SmartMoto interface. Please follow the instructions provided therein
Disconnect cable from the phone;
Remove and insert phone’s battery;
Press "Power on" key on the phone. Phone's LCD remains blank;
Connect cable to the phone;
Press OK in SmartMoto.
The handset should be detected by SmartMoto as "S Blank..."
SmartMoto restores the temporary backup file.
Log to bookmark "Unlock".
Pickup correct model from the scrolling list.
Press "Remove RSA".
Phone goes into boot mode. Reserve copy of security area is created.
Part of phone firmware is reflashed.
Phone doesn't power on after that. SmartMoto will give the message requiring to take phone into boot mode by pressing keys combination: *,#, PWR ON (at this moment the phone has to be connected with USB cable).
Press "OK" button. Wait till the process finishes.
Log to "Flash" tab.
Press "Enter flash mode".
The phone enters a flash mode (continue with the step 14, please).
P.S. Alternatively, the handset can be connected using a TestPoint method. After that log to bookmark "Flash", press "Enter flash mode" and continue with the step 14.
Press "Unlock via patch" button.
Wait for the process to complete.
Phone is unlocked. lụm tiền bỏ túi![]()
