MCU ID: 0x2292
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Checking path: \Products\RH-105\
No ini files found...
Phone Type:
MCU Flash file: D:\chuong trinh dien thoai\FILES FLASH\file flash nokia\pile lash tv\1208 RH-105_5.71\rh105_05.710
Phone Type:
PPM Flash file: D:\chuong trinh dien thoai\FILES FLASH\file flash nokia\pile lash tv\1208 RH-105_5.71\rh105_05.71mr
Setting local mode...
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: D:\chuong trinh dien thoai\FILES FLASH\file flash nokia\pile lash tv\1208 RH-105_5.71\rh105_05.710
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 845186E1D6A16E3608F554EC12
MSID decoded: 3E4EBAE900CB371FA8000000
FAID: 2F163BE0A3717F1CFF84254C
Operation took 0 minutes 11 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013AFFFF...
Erasing area: 013B0000 - 013EFFFF...
Operation took 1 minutes 21 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 15 seconds...
Restarting MCU...
PPM: D:\chuong trinh dien thoai\FILES FLASH\file flash nokia\pile lash tv\1208 RH-105_5.71\rh105_05.71mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Operation took 0 minutes 10 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0124FFFF...
Erasing area: 01250000 - 0137FFFF...
Operation took 0 minutes 26 seconds...
Writing...
Operation took 0 minutes 8 seconds...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 42 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-105, Software version: 5.71
IMEI: 356413021323956
Product Code: 0550577
Resetting PPC...
Done!
 LinkBack URL About LinkBacks
			 Ae xem dùm log.
 Ae xem dùm log.
