Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 28
    Thành viên chính thức sam_vina's Avatar
    Oct 2005
    Usa
    Thumbs up Unlock Samsung SGH-D807
    1. If you have changed your phone password, change your password back to the default 8 zeros (00000000).
    1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
    2. Put a SIM card that is from a network other than the one your phone is locked to (I used a TMOBILE card from my buddy Darin)
    3. When Incorrect SIM (I got invalid card and there was a sim card graphic spinning) error comes up, type *#9998*3323#.
    4. White screen will appear with an exit option. Press the right softkey. (I ended up pushing the down key to get a menu)
    5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear.
    6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear.
    7. Turn off your phone and put the original SIM back in.
    8. Turn on your phone. You will receive a prompt to enter a password.
    9. Type 8 zeros (00000000) (This is because the SIM LOCK Mentioned earlier gets switched back on)
    10. Completed. You have now unlocked your phone.
    www.suachuadtdd.com
    unlock iphone - Repair board GSM - NO WIFI
    Thành viên chính thức bao chua's Avatar
    Oct 2005
    Hải Phòng
    cái này anh test chưa vậy ??? sao nó giống cách unlock cho x660 vậy nhỉ
    BaoChua returns
    Thành viên chính thức MotoX's Avatar
    Apr 2006
    Loằng quằng mệt lắm Mr.Hồng
    UFS + cable D800 + chọn D808 >> direct unlock >>. thế là xong.
    (D807 = hàng Mỹ)
    MotoFONE_F3_R3T621_G_15.08.03I
    Thành viên kỳ cựu cotaomobile's Avatar
    Sep 2005
    Trích Được post bởi MotoX
    (D807 = hàng Mỹ)
    Anh ơi con này Unlock ra có dùng đc k anh ?có band 900/1800 ?
    em chưa gặp nhưng cảm ơn thông tin của anh rất nhềiu
    y/m : Cotaomobile_kg
    077.350.0099___091808.3663
    V.I.P trieubk's Avatar
    Jan 2006
    Trích Được post bởi cotaomobile
    đặc tính kỹ thuật D807
    Dimensions: 3.98" x 2.09" x 0.61"
    Weight: 3.30 ounces
    Main Display: 176 x 220 pixel, 262K TFT
    Color: Black and Chrome
    Continuous digital talk time: Up to 5 hours*
    Standby Time: Up to 250 hours*
    Mode: GSM quad-band (850 / 900 / 1800 / 1900 MHz)
    Wireless Protocol: GSM
    Service Provider: Cingular
    Vi phạm nội quy langa's Avatar
    May 2006
    hi cách của anh motox nhanh gọn lẹ nhất nhưng cũng cám ơn thông tin của anh hồng
    Thành viên chính thức k8222503's Avatar
    Oct 2005
    Usa
    Mặc định hihiihi....
    (D807 = hàng Mỹ)
    Tay không chống mĩ mà anh........... cach của anh là dùng bom nguyên tử rồi....1 ngày nào đó ufs hư chơi cach nầy cũng tốt mà
    Thành viên mới mặt trời mới's Avatar
    Jan 2006
    (D807 = hàng Mỹ)
    cám ơn bác MotoXXX
    A B C
    Thành viên tích cực Quick850B's Avatar
    Mar 2006
    TPHCM
    (D807 = hàng Mỹ)
    máy này ufs xử lý ok..làm nhiều mắc công rối..
    ah kô biết có bác nào nạp TV cây này chưa ta..
    Thành viên mới duylinhmobile's Avatar
    Nov 2005
    www.otohanoi.com.vn
    Cây này chẳng khác gì cây D808 cả
  1. xin so đồ samsung D807
    By 99999 in forum Phần mềm Samsung
    Bài viết cuối: 02-08-2012, 22:21
  2. Cần mua màn hình Samsung D807 !
    By danhtin2006 in forum QUẢNG CÁO VÀ MUA BÁN
    Bài viết cuối: 05-10-2008, 17:39
  3. Unlock D807 1000%
    By KienGiangMoBile in forum SAMSUNG
    Bài viết cuối: 22-03-2007, 14:38
  4. Unlock D807
    By t&h in forum Agere System
    Bài viết cuối: 11-02-2007, 12:49
  5. Unlock D807
    By truongtho in forum Phần mềm Samsung
    Bài viết cuối: 04-10-2006, 10:43
