Unclock con W580i không thành công....
Ae trên forum giúp e unclock con sony W580i CID 53 với ver 0.915062
RUNNING v0.915062/UNI
CARD SERIAL 00152333
USBFLASH DRIVER VERSION 02.02.00.05
SIGNED MODE (USING SERVER)
CFG:100000000000
ChipID:9900,EMP protocol:0301
PHONE STATE: "RETAIL"
FLASH CID: 0053
Speed:921600
FLASH ID:897E
OTP: LOCKED:1 CID:51 PAF:1 IMEI:01157200461235 CERT:RED
FLASH CID:53 COLOR:RED
can't get packet start.
no ack during gdfs_readvar !
SCRC READ FAILURE
Elapsed: 37 secs.
CFG:100000000000
FLASH CID: 0053
Speed:921600
FLASH ID:897E
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35256002817952 CERT:RED
SCRC READ FAILURE
Elapsed: 35 secs.
CFG:100000000000
FLASH CID: 0053
Speed:921600
FLASH ID:897E
SCRC READ FAILURE
Elapsed: 12 secs.
CFG:100100000000
FLASH CID: 0053
Speed:921600
PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0
LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
FLASH ID:897E
writing "D:\Sofl DTDD\Sony\Sofl file\W580i\CiD53\R8BE001_1123476_CHINA_LA.ssw"
CURRENT FLASH FILE CID:53
SSW uses full hash, hash len is: 9200
Will flash 460 blocks...
writing "D:\Sofl DTDD\Sony\Sofl file\W580i\CiD53\R8BE001_FS_APAC_LA_RED_CID53.ssw"
SSW uses full hash, hash len is: 4820
Will flash 241 blocks...
LDR:070904 1245 begin_of_the_skype_highlighting 070904 1245 end_of_the_skype_highlighting AN2CXC1250562_DB2020_CSLOADER_R3A013
loader GDFS startup executed
loader FILESYSTEM startup executed
using GENERIC phone customization
tpa/preset/custom/C3_PCA_G3v2.cer
tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
tpa/preset/custom/customize.xml
tpa/preset/custom/DESKTOP_HOOK_2.itm
tpa/preset/custom/Entrust.net Root Certificate.cer
tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
tpa/preset/custom/FM_PICTURES_HOOK_3.itm
tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
tpa/preset/custom/FM_THEMES_HOOK_3.itm
tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
tpa/preset/custom/GAMES_HOOK_3.itm
tpa/preset/custom/GTE_CyberTrust_Root.cer
tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
tpa/preset/custom/Root.cer
tpa/preset/custom/SEMC_E2E_Root_CA.crt
tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
tpa/preset/custom/ThawtePremium.der
tpa/preset/custom/ThawteServerCA.cer
tpa/preset/custom/Utiroot.cer
tpa/preset/custom/VeriSignClass3Root.cer
tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
Phone detached
Elapsed: 519 secs.
CFG:100100000000
FLASH CID: 0053
Speed:921600
FLASH ID:897E
Model (from GDFS):W580i
Brand:Generic
MAPP CXC article: R8BE001 prgCXC1123476_CHINA_LA
MAPP CXC version: R8BE001
Language Package: APAC
CDA article: CDA102568/1
CDA version: R2A
Default article: cxc1123364
Default version: R8BE001
PROVIDER: MULTIPLE
Network LOCKED
RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
SECURITY UNITS BACKUP CREATED.
Elapsed: 7 secs.
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:110000000000
FLASH CID: 0053
Speed:921600
FAILED TO SETUP PHONE
Elapsed: 3 secs.
CFG:110000000000
FLASH CID: 0053
Speed:921600
llbug: blk write fail. fatal
PROCEDURE WAS STOPPED BY USER
packet not acknowledged (3C)
payload block 6 NAK
Elapsed: 28 secs.
CFG:100100000000
FLASH CID: 0053
Speed:921600
FLASH ID:897E
Phone detached
Elapsed: 498 secs.
CFG:100000000000
FLASH CID: 0053
Speed:921600
FLASH ID:897E
Brand:Generic
CDA version: R2A
PROVIDER: MULTIPLE
Network LOCKED
Elapsed: 7 secs.
PRELOADER SECURITY BYPASS ENABLED
CFG:111000000000
FLASH CID: 0053
Speed:921600
FLASH ID:897E
DISCONNECT PHONE NOW
INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
INSTALL PHONE MODEM DRIVERS IF NEEDED
SEARCHING FOR PHONE, "STOP" TO ABORT
PHONE FOUND AT COM19
PHONE READY TO PROCEED
There is NO EXECUTOR in phone !
Elapsed: 100 secs.
CFG:100100000000
FLASH CID: 0053
Speed:921600
FLASH ID:897E
Phone detached
Elapsed: 524 secs.
CFG:100000000000
FLASH CID: 0053
Speed:921600
FLASH ID:897E
Brand:Generic
CDA version: R2A
PROVIDER: MULTIPLE
Network LOCKED
Elapsed: 6 secs.
CFG:110000000000
FLASH CID: 0053
Speed:921600
FLASH ID:897E
PHONE FOUND AT COM15
Elapsed: 84 secs.
E làm tới đây....vẫn chưa unclock được ae nào có kinh nghiệm giúp e vượt qua lỗi này
