Kết quả 1 tới 10 của 11
    Mặc định 2700c bị cà tưng cần giúp đỡ!
    máy khách đang sài tự nhiên no hay mất nguồn , mình cho vào jaf và nbox chạy cho em nó phát nhưng cũng vậy nên cho sang mkey quất em nó phát nữa bây giờ nó lên nokia rồi trắng màn hình và t
    Version from file: 09.97
    Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010)
    Reading phone`s ID ...
    ROM ID: 273F6D55DFAAF68F
    productData saved.
    Restarting phone ...
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 150002053C2A8E56190E3E14F91841F362182D50
    ASIC MODE ID: 00
    FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,CMT
    TransmissionMode: 16Bit
    TransmissionMode: DDR&TX2
    Reading CMT HWC (0xD4 bytes).
    Flash Imei: 35151704411345
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    SIMLOCK_DATA saved OK
    SIMLOCK_KEY_DATA saved OK
    SUPERDONGLE_KEY_DATA saved OK
    CMLA_KEY_DATA saved OK
    WMDRM_PD_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    LOCK120_DATA saved OK
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35151704411345_BA CK.rpl"
    Processing MCU file: rm561__09.97.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 21.00 MB
    CMT NOR area [00000000-000006BF] erased in 0.625 s
    CMT NOR area [000006C0-0001FFFF] erased in 0.156 s
    CMT NOR area [00040000-000BFFFF] erased in 2.032 s
    CMT NOR area [000C0000-0013FFFF] erased in 0.219 s
    CMT NOR area [00140000-0137FFFF] erased in 1 min 6.609 s
    CMT NOR area [01380000-0151FFFF] erased in 6.610 s
    Flash programming ...
    CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100303130 (RAP Certificate 202 v.1) written.
    Programming completed in 11 min 52.234 s
    Processing PPM file: rm561__09.97.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.90 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 8.62 MB
    CMT NOR area [01520000-01DBFFFF] erased in 27.281 s
    Programming completed in 4 min 31.906 s
    Processing CNT file: rm561__09.97.image_v_red
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 34.00 MB
    CMT NOR area [01DC0000-0215FFFF] erased in 14.812 s
    CMT NOR area [02160000-03FBFFFF] erased in 1 min 13.094 s
    Converting UCP blocks to 128 K.
    Programming completed in 8 min 33.828 s
    Total time for flashing process(boot+erase+write) was 28 min 32.422 s
    Flashing completed in 30 min 23.453 s
    Phone Type: RM-561 (Nokia 2700 classic)
    SW Version: V 09.97 18-06-10 RM-561 (c) Nokia
    Imei plain: 35151704411345-2
    Product Code: 0579808
    Language Pack:
    - not available.
    This is SL3 phone(Simlock2 format).
    - Avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 351517044113452
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    ắt nguồn vậy là sao ae log của em nó đây ae xem giúp
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    SIMLOCK_TEST passed
    lỗi đó bạn cho vào reaper lại nạp pm full ok
    not ok qua yahoo mình coi dùm cho
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    Trích Được post bởi tlpmobile_tk Xem bài viết
    SIMLOCK_TEST passed
    cái ni bình thường mà bạn có răng mô,
    chạy ver cao hơn hoặc cho sang box khác nếu vẫn not ok thì gia cố lại IC Flash
    Thành viên mới kunpack's Avatar
    Mar 2011
    SIMLOCK_TEST passed
    cai log bình thường mà nói lỏi .sl3 còn repair wr pm full nủa chứ.hehee
    TP Hồ Chí Minh
    cây này bảo đảm không hết. chỉ có cách lắc lại U. Nhưng U flash chung hơi mệt, kekeke....
    Krông Nô - Đăk Nông
    Trích Được post bởi imnhaque Xem bài viết
    gì đây vậy PA mền chưa làm xong làm cứng ôm hận cả đời máy sác vô số kể ah
    Thành viên chính thức thanhvubloc's Avatar
    mình có 1 cây chạy hết cách từ jar nbox mxkey rồi tới mt cũng bó tay. chắc phải múc u thôi. đang sợ đền máy nên chưa dám làm
    vậy phải trả máy sao ae !!!!!!!!!!!!!!!!!!!!!
    V.I.P tôn tẩn's Avatar
    A HÙNG VÙNG 7 NÚI
    có đền mới biết bệnh of nó chứ như vậy mới có kinh nghiệm
    Thành viên chính thức bexelet's Avatar
    Dec 2010
    Lâu lâu cắn ớt là chuyện bình phường
  1. sem giúp em cái log 2700c
    By hovietluy in forum BB5
    Bài viết cuối: 22-12-2012, 20:02
  2. xin giúp hạ ver 2700c thanks
    By lenhan in forum BB5
    Trả lời: 19
    Bài viết cuối: 08-10-2011, 13:53
  3. Trả lời: 15
    Bài viết cuối: 01-06-2011, 12:30
  4. xin giúp 2700c
    By hoangthanh277 in forum BB5
    Bài viết cuối: 04-04-2011, 18:25
  5. 2700c cần giúp
    By trungphuong1988 in forum BB5
    Bài viết cuối: 28-11-2010, 11:19
