Kết quả 1 tới 10 của 11
    Thành viên mới k3ntvjp's Avatar
    Mặc định 2700c hiện contact service
    máy ban đầu có mạng ko sóng,e write pm xong bật nguồn ko gắn sim nhấn khởi động máy ko cần thẻ sim thì bị cs rồi tắt luôn,e chạy lại ver cao hơn vẫn vậy,unlock ko đc
    log info jaf:
    Booting phone...
    FAST PHONE detected!
    CMT Boot Data:
    Asic ID: 000000010000022600010006030C192101033000
    Asic Mode ID: 00
    Asic EM ID: 00000B22
    Asic Public ID: 146000082A084E50593F3422CC28C1AA3CB66531
    HASH: 9DDBFCFE6E73CED7D8C6268C8EB8572300000000
    ROM ID: 273F6D55DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 240000EC <=> SAMSUNG (SEC) -> Type not in database
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 01.21.01 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 09.98
    06-09-10
    RM-561
    (c) Nokia
    HW version: 2000
    PCI version:
    RFIC version:  06540601
    DSP version:
    ICPR72_09w26
    LCD version: SEIKO
    PPM version: V 09.98
    06-09-10
    RM-561
    (c) Nokia
    V
    BT MCM version: 2222-302
    Retu version: 16
    Tahvo version: 22
    Content Pack version: Content: v_grey
    V 09.98
    06-09-10
    RM-561
    (c) Nokia
    Production serial number: ICS829625
    Product code: 0588814
    Module code: 0204245
    Basic production code: 0577212
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 353417040495987
    IMEI spare to net: 3A 35 14 07 04 94 95 08
    IMEI SV to net: 33 35 14 07 04 94 95 58 F5
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 0000000000000000
    Provider: Unknown provider
    Key Code count: 0, FBUS Code count: 0
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-561.ini
    Setting local mode...
    Reading product code...
    Product Code: 0588814
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-561\
    Checking path: \Products\RM-561\
    No ini files found...
    Done!
    Thành viên chính thức huuthuongsl's Avatar
    bạn chạy = hộp gì ?
    Thành viên mới sitien's Avatar
    Jun 2006
    mang qua mx sửa lỗi bạn
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    cho cái log check bằng mxkey coi bạn.may ra thì còn chứ không active mxkey thì ok
    MX-key
    RAP Data :
    EM1 ID: 00000296
    EM2 ID: 00000B22
    PUBLIC ID: 146000082A084E50593F3422CC28C1AA3CB66531
    ASIC MODE ID: 00
    rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,RAP
    ExtDEVC: FFFF 0000 - 0000 0000
    RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    RAP PAPUBKEYS ID: 3EA22A1DDA660002E56108DB5072A10F8709443F
    Original Imei: 35341704049598
    Original Product code: 0581057
    Bluetooth ID: 20D6079C2209
    Phone Type: RM-561 (Nokia 2700 classic)
    SW Version: V 09.98 06-09-10 RM-561 (c) Nokia
    Imei plain: 35341704049598-7
    VariantId: V
    Language Pack:
    - not available.
    SIMLOCK invalid!
    SIMLOCK_TEST failed!
    SECURITY_TEST passed
    SIMLOCK_DATA corrupted!
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    banh cái simlock đó rồi
    trước khi làm có backup lại không ?
    nếu không thì tết đến nơi rồi không biết ai có thể giúp được bạn giờ
    V.I.P HoangViet902's Avatar
    Núi Bà Đen
    simlock banh xác rồi , có backup thì write lại , không backup thì thay cặp , không backup hiện tại all box đều ngồi ngó
    Moderator DuyQNgãi's Avatar
    Quảng Ngãi City
    SIMLOCK_TEST failed! mà không có file backup chắc qua tết kiếm cặp thay vào anh
    Krông Nô - Đăk Nông
    mang qua hoàng thông mấy anh đó làm hộ chắc khoảng 500k á không thì lấy cặp khác đóng vào anh à
    Vi phạm nội quy phamtuyenz1's Avatar
    Feb 2010
    Paraguay
    thành thật chia buồn cùng a nếu máy nhà thì để đó chờ đi a nghe nói mx thời gian sau sẽ free
  1. 2700c contact service xin giúp !
    By trongtan8909 in forum BB5
    Bài viết cuối: 04-08-2012, 11:44
  2. Trả lời: 13
    Bài viết cuối: 12-07-2012, 09:56
  3. 2700c báo contact service
    By ducmobile84 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 15-12-2011, 14:28
  4. 2700c contact service
    By thanhtungtrieuson in forum BB5
    Bài viết cuối: 04-12-2011, 09:05
  5. 2700c contact service xin giúp ?
    By bomnokia in forum BB5
    Bài viết cuối: 01-09-2011, 08:58
