    Apr 2008
    đồng tháp lạc đến An giang
    Mặc định 2700c mất nguồn
    Anh em xem giúp cáo log 2700c mất nguồn em nạp Flash nó lên nguồn hiện dòng NOKIA rồi trắng luôn,men chua sữa chữa...anh em thao khảo LOG của em nó..cho em ý kiến .thanks anh em nhiều
    Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010)
    Processing MCU file: rm561__09.95.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    Waiting for USB device ...
    Pooling for ADL device ...
    Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 17A842B4
    CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 02600118AD4E8E56F1AE230C0CE13B91CA94EDB0
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROM ID: 273F6D55DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x3900 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
    Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 10688386
    Verifying communication to device OK.
    Erase size: 21.00 MB
    CMT NOR area [00000000-000006BF] erased in 0.625 s
    CMT NOR area [000006C0-0001FFFF] erased in 0.563 s
    CMT NOR area [00040000-000BFFFF] erased in 2.390 s
    CMT NOR area [000C0000-0013FFFF] erased in 2.563 s
    CMT NOR area [00140000-0137FFFF] erased in 1 min 20.125 s
    CMT NOR area [01380000-0151FFFF] erased in 7.469 s
    Flash programming ...
    CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100374333 (RAP Certificate 202 v.1) written.
    Programming completed in 1 min 37.078 s
    Processing PPM file: rm561__09.95.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.90 MB
    Erase size: 8.62 MB
    CMT NOR area [01520000-01DBFFFF] erased in 39.766 s
    Programming completed in 35.187 s
    Processing CNT file: rm561__09.95.image_v_blac_128
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.70 MB
    Erase size: 34.00 MB
    CMT NOR area [01DC0000-0215FFFF] erased in 17.141 s
    CMT NOR area [02160000-03FBFFFF] erased in 2 min 24.641 s
    UCP page size is 128 K.
    Programming completed in 1 min 6.797 s
    Total time for flashing process(boot+erase+write) was 8 min 29.656 s
    Timeout, no usb device found.
    Flashing completed in 9 min 21.406 s
    Phone not responding !
    Market items is empty, please select the correct products path !
    CỬA HÀNG ĐTDĐ THÔNG THÁI
    Apr 2008
    em đã chạy nó bằng MX cáp ốp lưng và USB vẫn vậy,N box HWK cũng không khỏi bệnh
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    có mtbox không anh flash lại cái cho nó thêm cái ver cao đụng nóc vào nữa
    Apr 2008
    em không có MT chỉ có JAF và mx nbox hwk,còn cách nào không các bác
    V.I.P anhvanmobi's Avatar
    cho em nó một ver tới nóc đi ban 2700-rm-561-9.97
    ftp://download.saigonmobile.vn/FLASH...700c%20rm-561/
    Sóc Sơn - Hà Nội
    tạm dich thế này !
    Thư viện của phiên bản: 1.0.0.9100 (23-12-2010), 1.0.0.15151 (24-12-2010)
    Chế biến file MCU: rm561__09.95.mcusw
    [BB5, BB5 THUẬT TOÁN] kích thước: 19,41 MB
    Hỗ trợ Id: 010C192101013000, 0103192101003000, 030C192101033000
    Hãy chắc chắn rằng cáp USB, pin và bộ sạc được loại bỏ từ thiết bị.
    Chèn cáp USB, pin trở lại thiết bị (hãy chắc chắn để có được sạc đầy pin).
    Sạc hoặc nút Insert điện báo điện thoại (nếu nhấp nháy doesnt tự khởi động)
    Đang chờ thiết bị USB ...
    Góp cho ADL thiết bị ...
    Thiết bị tìm thấy: nmwcdnsuc \ Nokia USB Flash Chung, ID: 17A842B4
    CMT HỆ THỐNG ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
    CMT công ID: 02600118AD4E8E56F1AE230C0CE13B91CA94EDB0
    CMT HASH ROOT KEY: 9DDBFCFE6E73CED7D8C6268C8EB85723
    Flashing CMT Server Update dữ liệu, ULO: 0x3900 bytes
    Thông tin Server mã thành công gửi đến điện thoại.
    Flashing CMT Server Update dữ liệu, UPDAPP: 0x4B340 byte
    Flashing CMT Server Update dữ liệu, PASUBTOC: 0x59980 byte
    Thiết bị tìm thấy: nmwcdnsuc \ Nokia BB5 ADL Loader USB Generic, ID: 10688386
    Xác minh thông tin liên lạc vào điện thoại OK.
    Xoá bỏ kích thước: 21,00 MB
    NOR CMT khu vực [00000000-000006BF] xóa trong 0,625 s
    NOR CMT khu vực [000006C0-0001FFFF] xóa trong 0,563 s
    NOR CMT khu vực [00040000-000BFFFF] xóa trong 2,390 s
    NOR CMT khu vực [000C0000-0013FFFF] xóa trong 2,563 s
    NOR CMT khu vực [00140000-0137FFFF] xóa trong 1 phút 20,125 s
    NOR CMT khu vực [01380000-0151FFFF] xóa trong 7,469 s
    Flash lập trình ...
    CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100374333 (RAP Giấy chứng nhận 202 v.1) bằng văn bản.
    Lập trình hoàn thành trong 1 phút 37,078 s
    Xử lý PPM file: rm561__09.95.ppm_v
    [BB5, BB5 THUẬT TOÁN] kích thước: 6,90 MB
    Xoá bỏ kích thước: 8,62 MB
    NOR CMT khu vực [01520000-01DBFFFF] xóa trong 39,766 s
    Flash lập trình ...
    Lập trình hoàn thành trong 35,187 s
    Chế biến file CNT: rm561__09.95.image_v_blac_128
    [BB5, BB5 THUẬT TOÁN] trang kích thước: 128 K thước: 13,70 MB
    Xoá bỏ kích thước: 34,00 MB
    NOR CMT khu vực [01DC0000-0215FFFF] xóa trong 17,141 s
    NOR CMT khu vực [02160000-03FBFFFF] xóa trong 2 phút 24,641 s
    UCP trang kích thước là 128 K.
    Flash lập trình ...
    Lập trình hoàn thành trong 1 phút 6,797 s
    Tổng thời gian cho quá trình flash (khởi động + xóa + viết) đã được 8 phút 29,656 s
    Hết thời gian, không có thiết bị USB được tìm thấy.
    Flashing hoàn thành trong 9 phút 21,406 s
    Điện thoại không được đáp ứng!
    Thị trường mặt hàng có sản phẩm nào, hãy chọn con đường sản phẩm chính xác!
    >> có lẽ bạn chọn sai file ! lạp lại file chuẩn đi bạn !
    Thành viên mới dung959's Avatar
    Dec 2010
    gỡ camera ra thử xem sao bạn
  1. 2700c mất nguồn
    By thuanwhisky90 in forum BB5
    Bài viết cuối: 04-07-2013, 12:17
  2. Trả lời: 12
    Bài viết cuối: 30-09-2012, 04:37
  3. 2700c bật nguồn chớp tắt
    By Nam Tào_Bắc Đẩu in forum BB5
    Bài viết cuối: 12-06-2012, 09:03
  4. 2700c mất nguồn
    By Apple179 in forum BB5
    Bài viết cuối: 05-01-2012, 16:00
  5. Trả lời: 14
    Bài viết cuối: 30-08-2011, 09:35
