    Thành viên chính thức makien's Avatar
    Dec 2008
    Mặc định dúp em 3110c han chế điện thoại
    em nhận của khách bị hạn chế điện thoại em có mxkay chạy log nó như này các anh dúp em với nhé
    em không rành lắm về phần mềm các anh dúp em cách repair =mxkay với
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35678902158537_BA CK.rpl"
    Processing MCU file: 3110c_TV_OK.mcusw
    [BB5,BB5 ALGORITHM] size: 14.49 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 0EB00004F15A7C565C1E790FF1F6C7F060DDFE6A
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT NOR area [00000000-000006BF] erased in 0.781 s
    CMT NOR area [000006C0-0001FFFF] erased in 0.234 s
    CMT NOR area [00020000-0007FFFF] erased in 2.344 s
    CMT NOR area [00080000-000DFFFF] erased in 0.234 s
    CMT NOR area [00100000-001FFFFF] erased in 0.375 s
    CMT NOR area [00200000-0031FFFF] erased in 6.344 s
    CMT NOR area [00320000-0105FFFF] erased in 1 min 8.719 s
    CMT NOR area [01060000-01067FFF] erased in 0.781 s
    CMT NOR area [01068000-0107FFFF] erased in 0.234 s
    Flash programming ...
    CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) written.
    Programming completed in 2 min 0.609 s
    Processing PPM file: 3110c_TV_OK.ppm_v
    [BB5,BB5 ALGORITHM] size: 4.35 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 4.62 MB
    CMT NOR area [01080000-0151FFFF] erased in 22.610 s
    Programming completed in 35.078 s
    Processing CNT file: 3110c_TV_OK.image_ora_pl_games_128
    [BB5,BB5 ALGORITHM] page size: 64 K size: 4.63 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 10.75 MB
    CMT NOR area [01520000-01FDFFFF] erased in 1 min 14.547 s
    UCP page size is 128 K.
    Programming completed in 37.266 s
    Total time for flashing process(boot+erase+write) was 6 min 33.578 s
    Flashing completed in 7 min 49.812 s
    Phone Type: RM-237 (Nokia 3110c)
    SW Version: V 07.30 07-05-09 RM-237 (c) Nokia.
    Imei plain: 35678902158537-5
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    SUPERDONGLE_KEY invalid!
    - WD timer enabled, phone will reboot itself after 3 min.
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 356789021585375
    Version: SIMLOCK SERVER VERSION 63
    Counter: 0/3, 0/10
    CONFIG_DATA: FFFFFFFFFFFFFFFF
    PROFILE_BITS: FFFFFFFFFFFFFFFF
    BLOCK 1: 1=CORRUPTED
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    bây giờ tiến hành repair lại cho nó thôi anh
    repair SD ,nếu secutryti fail thì sx4 viết pm remove 308 lại là ok
    Dec 2008
    em làm như vậy rồi sao không được nhỉ con cách j khác không anh
    Thành viên tích cực Tài mobile Độc®'s Avatar
    Oct 2010
    SIMLOCK có vẻ là hợp lệ
    SUPERDONGLE_KEY không hợp lệ!
    - WD bộ đếm thời gian kích hoạt, điện thoại sẽ khởi động lại chính nó sau 3 phút.
    SIMLOCK_TEST qua
    SECURITY_TEST được thông qua
    Net Imei: 356789021585375
    Phiên bản: SIMLOCK SERVER VERSION 63
    Lượt truy cập: 0 / 3, 0 / 10
    Block 1: 1 = hỏng
    coi lại từ đây mx-key lỗi
    Oct 2010
    SIMLOCK_TEST qua
    Block 1: 1 = hỏng
    Thành viên chính thức HiểnNokia's Avatar
    Bạn repair sd lại,unlock,nếu banh bảo mật thì write pm 1 với 309.Còn máy nếu đã có backup pm full thì write pm full lại là ok.3110c mx key unlock 1 phát là xong thôi.
    HiểnNokia - ĐT 0906675696 - yahoo ID:foxpro2002
    Dec 2008
    vâng để em thử nhé có j em báo kết quả
    Thành viên chính thức nguyenvu333's Avatar
    Dec 2008
    em làm được rồi làm như anh 0906675696 la ok
    cam on các anh hjhj
Hiện có 3 người đang xem bài này . Bao gồm : 0 thành viên và 3 khách
  1. 3110c hạn chế điện thoại
    By bocuaboy1994 in forum BB5
    Trả lời: 13
    Bài viết cuối: 10-08-2012, 13:29
  2. Trả lời: 25
    Bài viết cuối: 16-06-2011, 10:28
  3. 3110c hạn chế điện thoại
    By ANHTHUC in forum BB5
    Trả lời: 14
    Bài viết cuối: 21-01-2011, 18:48
  4. 3110c hạn chế điện thoại
    By nhucongquan in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 28-08-2010, 08:20
  5. Trả lời: 18
    Bài viết cuối: 07-06-2010, 15:11
