Kết quả 1 tới 3 của 3
    Thành viên tích cực cuocsongmoi's Avatar
    Mặc định n73 thỉnh thoảng cúp điện.
    đây là log của em nó.
    Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010)
    APE Data :
    SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
    ASIC MODE ID: 00
    PUBLIC ID: DCB9506DE1603F23FFB0BF6A3F2CAB996078D73A
    ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
    ROM ID: 1DFD66132C872FD4
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
    EM0 ID: 00000295
    EM1 ID: 00000B21
    PUBLIC ID: 29700112C1A7015438A026E946609B97BF4DBDE6
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
    TransmissionMode: DDR&TX2
    SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
    Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
    FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE
    ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
    Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
    APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
    Original Imei: 35364101485377
    Original Product code: 0529821
    Bluetooth ID: 001979E2FC40
    Phone Type: RM-133 (Nokia N73)
    SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia.
    Imei plain: 35364101485377-8
    Product Code: 0529821
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 353641014853778
    Version: SIMLOCK SERVER VERSION 63
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    Thành viên mới THANHLUAN™'s Avatar
    Dec 2010
    Tets thử quả pin khác xem anh +kiểm tra bis rùi tính tiếp !
    mình thay rồi nhưng vẫn vậy àh
    vậy cái log có bị sao không pro???
  1. Trả lời: 10
    Bài viết cuối: 11-01-2013, 11:27
  2. n72 chạm cúp ngườn
    By tr28 in forum BB5
    Trả lời: 15
    Bài viết cuối: 02-08-2009, 15:34
  3. xin nhạc midi cúp c1.
    By sàigòn in forum Chuông cho điện thoại di động
    Bài viết cuối: 29-07-2009, 08:13
  4. 7360 goi la báo pin yếu cúp nguồn?
    By thanhbinhc14 in forum DCT4 - WD2
    Bài viết cuối: 10-06-2009, 13:59
  5. V60i cúp điện xin giúp!
    By duydailoc in forum Acer - ODM - Old models
    Bài viết cuối: 01-09-2007, 20:31
