a nhận của khách máy 6230i bỏ pin nào vào cột pin cũng đầy hết .cục pin gần hết cũng vậy .e chạy lại cho nó rối mà vẫn k dc .ae nào biết chỉ e cách xử lý e này với
hotline : 0933221333 yh minhlong0379@yahoo.com
aribank 5902205130651 chi nhánh xuân lộc - đồng nai chủ tk : Trịnh minh long
LOG ĐÂY AE
Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010)
Rpl backup already exist (C:\mobileEx\3.4\data\backup\35326801990722_BACK.r pl).
Processing MCU file: rm72_73_11003.880
[TIKU BT2,TIKU ALGORITHM] size: 10.14 MB
Supported Ids: 1052, 2051
ASIC ID: 0x2051 [TikuEdge ver: 2.0]
SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398
Supported Ids: 1051, 1052, 2051
FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M)
FlashID2: 0000 0001 [unused/removed]
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5
Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8
UEM ID: 00E7CD74:8615DA60
Area [00000000-0000FFFF] erased in 0.500 s
Area [00010000-009FFFFF] erased in 1 min 6.844 s
Area [00A00000-00B3FFFF] erased in 8.687 s
Area [00B60000-00FAFFFF] erased in 29.391 s
Flash programming ...
Programming completed in 1 min 51.765 s
File Processed in 3 min 57.328 s
Processing CNT file: rm72_73_110M_03.88.ucp_t
[TIKU BT2,TIKU MON CSM] size: 3.93 MB
Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660
Mass Memory Storage Device detected.
Configuring MM bus ...
Formating partition ...OK
Opening MM device ...
Erasing disks ...OK
Programming completed in 1 min 2.625 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 0.875 s
File Processed in 1 min 31.766 s
Processing PPM file: rm72_73_110M_03.88t
[TIKU BT2,TIKU MON CSM] size: 4.57 MB
Erasing disks ...OK
Programming completed in 1 min 22.953 s
File Processed in 1 min 41.375 s
Flashing completed in 7 min 18.875 s
Phone Type: RM-72 (Nokia 6230i)
SW Version: V 03.88 28-Jul-06 RM-72 GSM P1.1 (c) NMP.
Imei plain: 35326801990722-5
Imei OTP: 35326801990722
Product Code: 0525615
Cellular System: GSM
ASIC ID: 0x2051, type: 6
Ppm Id: T
Language Pack:
English,Vietnamese,Tagalog,Chinese S,Chinese T
Imei net: 35326801990722
Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0100000000000006
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Cái nầy nên tận dụng kiến thức từ dct3 8210 sẻ rỏ hơn . Tốt nhất kiểm tra kỷ lại cái mạch sạc .
Bến Lức_Long An
minhthai379
bạn thử thay regu sạc coi có ok ko?
con nguồn đổ kéo đó làm con regu đi nằm ngay chấu pin đó.
Hạnh phúc là sự im lặng của nỗi đau và khi nỗi đau lên tiếng thì hạnh phúc không còn tồn tại.
thử thay regu, k đc nạp cho nó cái pm good xem sao
để nguồn 3,4 vom máy vẫn báo pin yếu .lên có 1 cục pin nhưng bỏ bin vào thì vẫn báo đầy .ae ai gặp rồi xin giúp
kiểm tra lại đường BSI trước nha bạn, coi máy vào các chế độ như local mode, test mode có ok ko nha
Cuộc đời vẫn là cuộc đời........ YM: tung_tn1
