some bb5 like 6280,6233,6234 etc shows CMT: FFFFFFFFFFFFFFFFFFFF
during fbus flashing
many user have this problem and many question about this problem and here is 1 good solution
its normally cable problem in most of case . u have to modify urs cable cause most of cable available in market are not modified so u have to modified it manually . if u cant modify then try USB flashing its simple and done by myself here are the logs as follows
1st fbus 7 pin cable but not modifiy
Phone Restarted...
Changing mode...Done!
Booting phone...
CMT Boot Data:
Asic ID: 000000010000022600010006010C192101003000
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 1E700117C6205A50031ED7E2E994DF7DFD4C3D75
HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
ROM ID: 273F6D55DFAAF68F
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 002F0001
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.16.00 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
Getting CMT Public Keys...
CMT Loader Ready
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_30005.100.mcusw
PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_3005.10.ppm_cvf
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_30005.10.image_cvf
Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese
Backing up CRT data...
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files\ODEON\JAF\ProgData\35454401411952_CRT_backup _1717109.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Setting local mode...
Failed! Aborting!
Failed to backup LCK...
Manual mode selected, version can't be checked!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Erasing...
Operation took 1 minutes 17 seconds...
Writing...
Stage 1
Sending CMT HASH for NOLO
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for PASUBTOC
Sending CMT PUB KEYS...
Sending CMT HASH for UPDAPP
Sending CMT HASH for DSP0
Sending CMT HASH for MCUSW
Sending CMT HASH for PMM_CONF
Sending CMT HASH for SBIF_CONF
Operation took 1 minutes 59 seconds...
Reseting phone...
PPM: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_3005.10.ppm_cvf
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Error in cmd1 par2...
Error loading cmt loader...
failed because of non modified cable
now if this problem occurs just simply use Dead USB flashing and urs phone will alive again here is usb flashing logs
2nd usb logs
JAF version 1.98.30
Detected PKEY: xxxxxxxxxxx
Card life counter: 85.49%
P-key nokia module version 01.00
Detected JAF INTERFACE version: 01.AF, Driver version: 40000, Library version: 30107
PRESS POWER ON THE PHONE NOW!!!
Searching for phone...Detected P-KEY: xxxxxxxxxxx
Init usb communication...
Found
Starting DEAD USB phone flashing...
Using 06.02.002
Elf2flash 02.31.000 RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... ................Loader Sent!
Stage 3 starting..........Phone prepared OK!
Waiting for the phone to boot...
Phone is in flash mode...
CMT blocks: 1434, APE blocks: 0
Erasing cmt...
Send CFG...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_30005.100.mcusw...
Erasing cmt zone 00000000 - 000006BF ...
Erasing cmt zone 000006C0 - 0000FFFF ...
Erasing cmt zone 00010000 - 0007FFFF ...
Erasing cmt zone 000A0000 - 0021FFFF ...
Erasing cmt zone 00220000 - 011DDFFF ...
Erasing cmt zone 011DE000 - 011DEFFF ...
Erasing cmt zone 011DF000 - 011DFFFF ...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_3005.10.ppm_cvf...
Erasing cmt zone 011E0000 - 016DFFFF ...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-123\rm123_145_30005.10.image_cvf...
Erasing cmt zone 016E0000 - 01E7FFFF ...
Erasing cmt zone 01E80000 - 01FDFFFF ...
Writing cmt...
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Rebooting...
Restarting CMT...
Pooling phone...
MCUSW: V 05.10
21-12-06
RM-145
(c) Nokia
APESW: (null)
VariantSW: (null)
Prodcode: 0535522
DCT4/BB5 counter: 22
Done!
so simply if u face this problem (CMT Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF)
just try dead usb flashing because not every time its hardware problem
