    vĩnh phúc
    Mặc định 1200 chết nguồn
    em nhận con 1200 chết nguồn em chạy pm thì có lúc lên contacsevic, có lúc ko lên, giờ máy bật nguồn chỉ sáng đèn màn hình và bàn phím mãi.em chưa làm j phần cứng mong các bác cho lời chỉ dạy.thanks nhìu ạ.
    đây là log em nó:Getting MCU ID
    MCU ID: 0x2292
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 5.91
    27-03-09
    RH-99
    (c) NMP
    HW version: 2502
    PCI version:
    UEM version: 1328
    UPP version: 8850
    RFIC version: 0700
    DSP version: ICPR62_08w31_UPP
    LCD version: UNKWN: IDs:
    00:ff:00
    PPM version: V 5.91
    27-03-09
    RH-99
    (c) NMP
    MR
    ADSP SW version: V 5.91\n27-03-09\nRH-99\n(c) NMP\nmr
    Production serial number: IER455138
    Product code: 0574499
    Module code: 0203402
    Basic production code: 0571402
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356868023297351
    IMEI spare to net: 3A 65 68 08 32 92 37 05
    IMEI SV to net: 33 65 68 08 32 92 37 75 F0
    Master Code: 6425120053
    Phone type: RH-99, Software version: 5.91, Language Pack: MR
    User code: ÿ#
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
    Setting local mode...
    Reading product code...
    Product Code: 0574499
    Checking path: \Products\RH-99\
    No ini files found...
    Done!
    Phone Type:
    MCU Flash file: D:\File phan mem NoKiA\Nokia-1200\1200_RH-99_v5.80.exe
    Phone Type:
    Reading...
    27-03-09
    RH-99
    (c) NMP
    HW version: 2502
    PCI version:
    UEM version: 1328
    UPP version: 8850
    RFIC version: 0700
    00:ff:00
    PPM version: V 5.91
    27-03-09
    RH-99
    (c) NMP
    MR
    Flash code:
    Order number:
    Long production SN:
    ATO:
    Default SN type:
    User code: ÿ#
    Done!
    Phone Type:
    MCU Flash file: D:\File phan mem NoKiA\Nokia-1200\1200_RH-99_v5.80\RH-99\rh99_05.800
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80mr
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80mr
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Failed to backup imei...
    MCU: D:\File phan mem NoKiA\Nokia-1200\1200_RH-99_v5.80\RH-99\rh99_05.800
    Booting phone...
    MCU ID: 0x2292
    Loader version: 04.4F.00 -> Revision: 0007
    Boot size is 0x09D8
    Boot is ready...
    Flash ID is 0x28882000
    Loader size is 0x4C68; Loader chk: ff
    Loader is ready...
    MSID: 841AD1230A808BA88F6698BAA2
    MSID decoded: 3E4EBAE900C602DCA9000000
    FAID: B1CA865F53FA183834C0C06B
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 14 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    MSID: 84591714A8E5262F61219CAD76
    MSID decoded: 3E4EBAE900C602DCA8000000
    FAID: 74B4C36A5715944A78A48573
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 23 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    MSID: 84ED3FE4974BA1F0BD14993593
    MSID decoded: 3E4EBAE900C602DCAA000000
    FAID: F7533FABA3F67C7DCC326DA1
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 27 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-99, Software version: 5.80
    IMEI: 356868023297351
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Unlocking...
    ASIC: b
    SW version: 5.80
    Selected flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
    Decrypting flash...
    Encrypting....
    CHK Patch found - Unlock Patch found and are not in same block
    Patch status: 01
    MCU ID: 0x2292
    Algo is ready...
    Erasing area: 01140000 - 0115FFFF...
    Unlocking...
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    MCU ID: 0x2292
    Algo is ready...
    Done!
    DCT4 unlock counter: 0
    Done!
    Jan 2010
    Quan Họ - Bắc Ninh
    anh làm con upp đi ... con này mỏi rồi anh...
    Dec 2008
    Phù Tiên
    thay CPU bạn ơi .
    Next Level 99,9
    vĩnh phúc
    vâng cám ơn 2 bác để em làm
    Thành viên mới mobile.'s Avatar
    Feb 2011
    em có cây 1200 mất imel có bác nào biết giúp em với
    korea
    Trích Được post bởi mobile. Xem bài viết
    bạn lập thear bài mới sẽ có người giúp bạn. thân ...
    hãy nhấn nút THANKS khi bài viết hữu ích cho bạn . thank all
    Jan 2010
    Quan Họ - Bắc Ninh
    anh lập topic mới nghea... quăng mei lên sẽ có người giúp anh nha...
  1. Trả lời: 5
    Bài viết cuối: 10-08-2013, 18:37
  2. 1200 chết nguồn
    By xecgayhiep in forum DCT4 - WD2
    Trả lời: 18
    Bài viết cuối: 08-07-2010, 20:15
  3. 1200 chập chờn nguồn
    By hunggsm in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 08-12-2009, 10:22
  4. 1200 chạm nguồn
    By Thanhtuanmobile in forum DCT4 - WD2
    Bài viết cuối: 20-11-2009, 21:51
  5. Trả lời: 2
    Bài viết cuối: 21-04-2009, 09:25
