máy bị đập. em mới làm chân lại CPU, họ muốn lấy lại danh bạ trong máy.
log
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C68
UEM ID: 00C9C814A3BDA66
ASIC type: 11
UEM Imei: 35310702873119
Flash Imei: 35310702873119
MasterCode: 5402065776
RPL saved to "C:\mobileEx\3.4\data\backup\35310702873119_BACK.r pl"
Phone Type: RH-99
SW Version: V 5.06 12-01-08 RH-99 (c) NMP
Imei plain: 35310702873119-4
Product Code: 0546885
Cellular System: GSM
ASIC ID: 0x2292, type: 0
Ppm Id: MR
Language Pack:
- not available.
Failed to read SP data
cho ý kiến anh em nha.thanks
A3BDA66
