    Thành viên mới shopAnhkhoa's Avatar
    Mar 2011
    Mặc định 7610 Chạy chương trình xong bị trăng+ chớp(sọc) xanh màn hình
    Log của nó đây. Em chạy = JAF nhờ anh em coi dùm
    Getting MCU ID
    MCU ID: 0x1081
    FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
    FLASH ID2: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 7.0642.0
    18-10-06
    RH-51
    (c)NMP
    HW version: 7019
    PCI version:
    UEM version: 144
    UPP version: 4225
    RFIC version: 0205
    DSP version: CN5.10
    PPM version: V 7.0642.0
    18-10-06
    RH-51
    (c)NMP.32
    BT MCM version:
    Production serial number: SDE053632
    Product code: 0514533
    Module code: 0202215
    Basic production code: 0520496
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO: s?????????????????????????????????????????????????
    Default SN type: s?????????????????????????????????????????????????
    IMEI plain: 355034005983960
    IMEI spare to net: 3A 55 30 04 50 89 93 06
    IMEI SV to net: 33 55 30 04 50 89 93 36 F3
    PDC: 4E 54 54 4A 50 12 34 56
    Master Code: 3731173066
    Phone type: RH-51, Software version: 7.0642.0, Language Pack: 32
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini
    Setting local mode...
    Reading product code...
    Product Code: 0514533
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
    Scanning for ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.05
    Languages in ppm: English,Italian,German (Italy)
    Done!
    Mar 2011
    không ai giúp em với ah
    Thành viên tích cực trantukiet1008's Avatar
    Dec 2009
    Xóa đi, flash lại bẳng Nbox thử sao anh
    Ai đem con cá đến cho con mèo
    nếu trắng vẫn nghe gọi thì test thử mh khác nha bạn
    Jan 2010
    Quan Họ - Bắc Ninh
    Trích Được post bởi DTDDT&M Xem bài viết
    cứ làm cho em nó cái mềm đã nha.,..... trước đó máy màn ok..... nạp lại file khủng nha.... cho sang jaf chạy cho khỏe.....
  1. lg su760 lên logo xong xanh man hinh
    By ko.ko80 in forum LG Android
    Bài viết cuối: 02-12-2013, 11:26
  2. 7610 rh-51 chạy pm xong báo
    By tuananh_mobile1990 in forum DCT4 - WD2
    Bài viết cuối: 13-09-2011, 10:04
  3. 7610 trăng mànhình
    By mainhancon in forum DCT4 - WD2
    Bài viết cuối: 27-10-2010, 12:26
