Kết quả 1 tới 10 của 12
    Thành viên chính thức MINH&THÙY_mobile's Avatar
    Mar 2011
    Mặc định 1202 rơi nước
    em nó bị rơi nước mik đã vệ sinh kỹ rồi+thay dao động+chạy pm mà vẫn k nên ,ace cho ý kiến
    log của e nó đây
    MCU ID: 0x2293
    FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-112 v4.03\rh112_004.030
    Booting phone...
    MCU ID: 0x2293
    Loader version: 04.4F.00 -> Revision: 0007
    Boot size is 0x09D8
    Boot is ready...
    Flash ID is 0x6822EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
    Loader size is 0x78C8; Loader chk: cc
    Loader is ready...
    MSID: 84C602A5B82E60C810E90493F2
    MSID decoded: 3E4EBAE900958159A9000000
    FAID: FDCF7C4082865CF845B8D8AA
    Erasing...
    Found 5 interval(s) to erase
    Operation took 0 minutes 27 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-112 v4.03\rh112_004.03mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    MSID: 84A4C1A29ECB6F43A55FFAE4C7
    MSID decoded: 3E4EBAE900958159A8000000
    FAID: EC63DF7F15374B720EBFFF6C
    Erasing Content Pack...
    Found 2 interval(s) to erase
    Operation took 0 minutes 9 seconds...
    Writing...
    Restarting MCU...
    Extracting Content Pack...
    CP Extract Failed!
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-112 v4.03\rh1120_nai04.03mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09D8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 1 minutes 30 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-112, Software version: 04.03
    IMEI: 353211032789733
    Product Code: 0563390
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Setting local mode...
    Reading imei...
    IMEI/ESN: 353211032789733
    Reseting warranty data...
    Reseting LifeTimer...
    Lifetime data not found!!!
    Done!
    MINHTHUY_MOBILE SERVICE CENTER
    DT:0973.991.386
    Jan 2010
    Quan Họ - Bắc Ninh
    dí nhẹ cho con upp xem sao nha...
    Mar 2011
    đã thử rồi bạn à
    DT:0973.991.386
    Jan 2010
    Quan Họ - Bắc Ninh
    Trích Được post bởi MINH&THÙY_mobile Xem bài viết
    đã thử rồi bạn à
    thay luôn đi anh zai nhé.... không chờ đợi...
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    rớt nước đầu tiên là vệ sinh > gia cố > thay mới thay con upp khác đi bạn
    May 2010
    ĐIỆN BIÊN
    CP Extract Failed!
    nghi cái này con upp có khả năng đã dea
    TRUNG HIẾU MOBILE
    Thành viên tích cực luckystar_qt's Avatar
    Oct 2009
    daklak
    sao chẳng ai nói đến cái màn hình nhỉ nc vào dễ die mạch màn hình lắm xem màn hình có mất chân nào không bác
    Mar 2011
    màn hình vẫn ngon,bấm nguồn dao đông đẹp
    DT:0973.991.386
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    hjx . sao ko thấy a nói đổi box khác +cái cáp chạy lại xóa full write .
    yahoo: viethuy_mobi
    Thành viên chính thức TIENKIEU_KRONGPA's Avatar
    Oct 2010
    chạy lại file khác xem sao bạn.kiểm tra đường bsi nữa nhe
    TRUNG TÂM ĐTDĐ TIẾN KIỀU MOBILE
    46 HÙNG VƯƠNG KRONGPA GIA LAI
  1. 1202 liệt phím
    By newbis in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 19-06-2012, 19:27
  2. 1202 ma bảo vệ
    By tranhoanggiang57 in forum DCT4 - WD2
    Trả lời: 15
    Bài viết cuối: 30-06-2011, 13:18
  3. xin fai pm cho 1202
    By quyduong191 in forum DCT4 - WD2
    Bài viết cuối: 19-09-2010, 08:09
  4. Trả lời: 0
    Bài viết cuối: 19-07-2010, 08:52
  5. Trả lời: 6
    Bài viết cuối: 15-02-2010, 09:38
