Kết quả 1 tới 10 của 20
    Thành viên chính thức thanhchien_mobi179's Avatar
    Dec 2009
    Mặc định 1202 imei ?????????? cần giúp
    Getting MCU ID
    MCU ID: 0x2293
    First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
    Checking path: \Products\RH-112\
    No ini files found...
    Phone Type:
    MCU Flash file: C:\program files\Nokia\Phoenix\Products\RH-112\rh112_004.030
    Phone Type:
    PPM Flash file: C:\program files\Nokia\Phoenix\Products\RH-112\rh1120_nai04.03mr
    Phone Type:
    CNT Flash file: C:\program files\Nokia\Phoenix\Products\RH-112\rh112_004.03mr
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\program files\Nokia\Phoenix\Products\RH-112\rh112_004.030
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 8420F6343522DEB0F9CCA333EF
    MSID decoded: 3E4EBAE9000864DEA9000000
    FAID: BE86293C3F6E6E1EA977A49E
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 4 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    CNT: C:\program files\Nokia\Phoenix\Products\RH-112\rh112_004.03mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84130A72B20B6C8F4F2A60CEA9
    MSID decoded: 3E4EBAE9000864DEA8000000
    FAID: 056C1C33110B259CA39687CC
    Erasing Content Pack...
    Found 2 interval(s) to erase
    Operation took 0 minutes 20 seconds...
    Writing...
    Restarting MCU...
    Extracting Content Pack...
    CP Extract Failed!
    PPM: C:\program files\Nokia\Phoenix\Products\RH-112\rh1120_nai04.03mr
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 36 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-112, Software version: 04.03
    IMEI: ???????????????
    Product Code: 0562324
    Resetting PPC...
    Done!
    Powering the phone...
    Unlocking...
    ASIC: b
    SW version: 04.03
    Unlock not supported!
    Failed! Aborting!phải làm gì đây mong anh em giúp.thanks.
    Thành viên kỳ cựu setot_thoi's Avatar
    Sóc Trăng
    gửi log là lụm tiền . . .
    MẩnMobile .Y/H : Jimmyphong10
    Thành viên tích cực trantukiet1008's Avatar
    Dec 2009
    read ask, quăng lên, ae nào có cho một lock, về write vào, write thêm cái pm nữa rồi unlock done
    Ai đem con cá đến cho con mèo
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    có mx thì cho vào để nó làm lun anh
    Dec 2009
    em chỉ có jaf thôi anh ơi.
    Thành viên chính thức baoduc_ayunpa's Avatar
    Mar 2011
    nghèo vậy bạn.có mxkey chua đầy 5p là no sử lí song rồi.read ASk quăn lên xem ae nào có thì cho 1 log.
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    ried ime ra rùi ae send cho 1log write vào là ok mà
    yahoo: viethuy_mobi
    Dec 2009
    ỏ we mình có jaf là ok lắm rùi đó.nhà ngèo phải chiu thui.
    Dec 2009
    read ASk là j có thể hướng dẫn cụ thể cho em với .kinh nghiệm còn yếu mong mọi người giúp .thanks
    Thành viên mới bgtedbyrho's Avatar
    Oct 2009
    đọc imei lên free log ko giới hạn
  1. 1202 mất imei xin anh em giúp đỡ
    By cauphamvan in forum DCT4 - WD2
    Bài viết cuối: 29-09-2011, 09:50
  2. 1202 imei ???????????????????/ xin giúp
    By Phungmobi in forum DCT4 - WD2
    Bài viết cuối: 05-08-2011, 17:41
  3. 1202 imei ????????????4 .nhờ mấy anh giúp
    By NgocAnQNgai in forum DCT4 - WD2
    Bài viết cuối: 31-07-2011, 09:13
  4. xin giúp 1202 imei ???????????????????
    By duchien_mobile331986 in forum DCT4 - WD2
    Bài viết cuối: 20-05-2011, 17:18
  5. 1202 IMEI??????? cần giúp
    By trungtramthan in forum DCT4 - WD2
    Bài viết cuối: 22-06-2010, 19:49
