em nhận con 1209 của khách tình trạng mất míc, rm tháo máy ra thấy nhiều bẩn tại tiếp xúc mic. em lau sạch lắp vào dùng đuọc 1 phút sau nó chết nguồn bật ko lên. em cho vào chạy pm nó báo vậy nè nhờ các bác xem dùm em cái long, giờ em nó lên contacsevic.em đã tháo mên ra mà vẫn ko hết
log đây ạ:Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011)
Rpl backup already exist (C:\mobileEx\3.4\data\backup\35680302160789_BACK.r pl).
Processing MCU file: rh105_05.910
[DCT4,DCT4 ALGORITHM] size: 2.28 MB
Supported Ids: 2292
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 005839E3:2984DA60
Area [01000000-0100FFFF] erased in 1.360 s
Area [01010000-013AFFFF] erased in 1 min 17.343 s
Area [013B0000-013EFFFF] erased in 5.375 s
Area [017C0000-017EFFFF] erased in 0.125 s
Area [01FC0000-01FEFFFF] erased in 0.125 s
Flash programming ...
Programming completed in 19.063 s
File Processed in 1 min 53.828 s
Processing CNT file: rh1050_nai5.91ad
[DCT4,DCT4 ALGORITHM] size: 118.40 KB
Supported Ids: 2292
Area [01380000-013AFFFF] erased in 4.016 s
Programming completed in 1.062 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.171 s
File Processed in 19.625 s
Processing PPM file: rh105_05.91ad
[DCT4,DCT4 ALGORITHM] size: 1.18 MB
Supported Ids: 2292
Area [01240000-0124FFFF] erased in 1.391 s
Area [01250000-0137FFFF] erased in 25.640 s
Programming completed in 9.953 s
File Processed in 47.328 s
Total time for flashing process(boot+erase+write) was 3 min 0.796 s
Phone Type: RH-105
SW Version: V 5.91 27-03-09 RH-105 (c) NMP
Imei plain: 35680302160789-7
Product Code: 0549920
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: AD
Language Pack:
- not available.
Imei net: 35680302160789
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000010000
SIMLOCK_DATA corrupted!
