    Thành viên tích cực trangiaminh's Avatar
    Mặc định 1202 chạy ok không lên nguồn
    mình có cây 1202 chay hwk log báo vậy ae xem giúp mình tay
    1st Boot: Ok, DCT4, UPP: 2293 [Rh-112] [2.1.0.0]
    2nd Boot: u3_2nd.fia, Ver: 4.79.0
    Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032
    Algorithm: u3_st_i.fia, Ver: 4.79.0
    Algorithm Ok, MSID: 840DC8732C36AF6DFC97CB1B67
    Decoded MSID: 3E4EBAE9-00311A2D-A9000000
    Encoded FAID: DD140330-8D7DDCC6-9CEBB46C
    IMAGE: rh112_004.030
    Area1: 0x01000000-0x0100FFFF Erased, Time: 00:01
    Area2: 0x01010000-0x013AFFFF Erased, Time: 01:13
    Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:06
    Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
    Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
    MCU Flashing Completed, Time: 00:14
    IMAGE: rh1120_nai04.03mr
    Area1: 0x01380000-0x013AFFFF Erased, Time: 00:03
    CNT Flashing Completed, Time: 00:00
    Running: Server fake reply for CUI phone.
    Contents Package Extracting Ok, Time: 00:07
    Algorithm Ok, MSID: 84B679BC14FFE13F93392B7B93
    Decoded MSID: 3E4EBAE9-00311A2D-A8000000
    Encoded FAID: 444BE170-1B26D369-68B6066A
    IMAGE: rh112_004.03mr
    Area1: 0x01240000-0x0124FFFF Erased, Time: 00:01
    Area2: 0x01250000-0x0137FFFF Erased, Time: 00:24
    PPM Flashing Completed, Time: 00:07
    Flashing Completed, Rebooting Mobile
    còn đây là log mx key
    Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010)
    ASIC ID: 0x2293 [UPPCosto ver: 2.0]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
    Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
    UEM ID: 00311A2DA3BDA66
    ASIC type: 11
    UEM Imei: 35828503170156
    Processing MCU file: rh112_004.030
    [DCT4,DCT4 ALGORITHM] size: 2.29 MB
    Supported Ids: 2293
    UEM ID: 00311A2D:2984DA60
    Area [01000000-0100FFFF] erased in 1.235 s
    Area [01010000-013AFFFF] erased in 1 min 10.563 s
    Area [013B0000-013EFFFF] erased in 4.937 s
    Area [017C0000-017EFFFF] erased in 0.110 s
    Area [01FC0000-01FEFFFF] erased in 0.110 s
    Flash programming ...
    Programming completed in 17.437 s
    File Processed in 1 min 42.562 s
    Processing CNT file: rh1120_nai04.03mr
    [DCT4,DCT4 ALGORITHM] size: 110.54 KB
    Supported Ids: 2293
    Area [01380000-013AFFFF] erased in 3.656 s
    Programming completed in 0.859 s
    Content extract fail, continue anyway ...
    File Processed in 38.094 s
    Processing PPM file: rh112_004.03mr
    [DCT4,DCT4 ALGORITHM] size: 1.15 MB
    Supported Ids: 2293
    Area [01240000-0124FFFF] erased in 1.234 s
    Area [01250000-0137FFFF] erased in 23.172 s
    Programming completed in 8.640 s
    File Processed in 43.437 s
    Flashing completed in 3 min 40.110 s
    Phone not responding !
    người ta sửa máy thì tài,tôi đây sửa máy khò uem chết cpu;)yahoo ...[love_forever_260l
    Thành viên chính thức ThuậnPhát_IT's Avatar
    Nov 2010
    Anh thử đem qua tiếp box jaf chiến coi kiếm cáp good vào kiểm tra cái màn hình hàn lại cho nó chắc chắn
    PHẬN LÀM TRAI GÕ PHÍM BÌNH THIÊN HẠ
    CHÍ ANH HÙNG KICH CHUỘT ĐINH GIANG SƠN
    Thành viên tích cực luckystar_qt's Avatar
    Oct 2009
    daklak
    Phone not responding ! zậy mà nói là chạy ok hử a đâu có đồng bộ đc đâu máy ban đầu bbij gì thế a rớt đất hay nc
    Vi phạm nội quy tuyetnhi_2007's Avatar
    anh chay ok sông mà anh có full factory có dc ko anh nếu mà full factory ko dc thi chua vào dc chế do local mode thi ko lên nguồn dc anh á
    May 2010
    ĐIỆN BIÊN
    xóa full nạp lại bằng hwk chạy lại phải factory nhé.coi lại cái mạch lcd luôn
    TRUNG HIẾU MOBILE
    Thành viên tích cực vantungnguyen's Avatar
    Nov 2010
    chạy bằng MXkey đến khi chạy file ppm thì máy báo phone not responding không anh. xong anh ấn cancel thì nó chạy tiếp. đúng ko vậy. mang qua HWK chạy thử hoặc JAF chạy thử nha. bệnh này không chắc nhưng hình như là do BSI
    Cuộc đời vẫn là cuộc đời........ YM: tung_tn1
    Thành viên chính thức phuccbbc's Avatar
    gẩy mỗi con n2n 4 chân bên con cpu lụm $ ngay cơ bản là do bis gây ra
    đồng bộ lại đi
    CHIÊU ANH ĐT:0933878095
  9. ( chieuNK ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tamdanh1_2mobile (26-04-2011)
  10. #9
    Thành viên chính thức tamdanh1_2mobile's Avatar
    Feb 2011
    chạy lại bạn oi ,chưa thnhf công mà ,nếu o được ,đóng lại cpu ,fla ,,,cố lên ,o gì khgó
  1. Trả lời: 12
    Bài viết cuối: 31-08-2014, 10:57
  2. 1202 treo máy không lên nguồn sau khi chạy pm
    By kevintran77 in forum DCT4 - WD2
    Bài viết cuối: 09-02-2012, 21:24
  3. Trả lời: 6
    Bài viết cuối: 17-07-2011, 07:07
  4. Trả lời: 8
    Bài viết cuối: 22-01-2011, 12:20
  5. 1202 chạy pm ok hết bật không lên nguồn
    By luanmobi in forum DCT4 - WD2
    Bài viết cuối: 27-11-2010, 22:14
