e có con 1661 rơi nước khách đem vào e sấy xong lắp vào nó báo contacsevic bỏ vao jaf chek báo thế này anh em giúp em với em không co mxkey
Getting MCU ID
MCU ID: 0x2293
FLASH ID0: 225400EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 04.30
06-07-09
RH-122
(c) Nokia
HW version: 1500
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_09w17_U
LCD version: WIN:BOHAIv91
NT39121
PPM version: V 04.30
06-07-09
RH-122
(c) Nokia
MR
ADSP SW version: V 04.30\n06-07-09\nRH-122\n(c) NMP\nmr
Production serial number: IFQ867445
Product code: 0575936
Module code: 0204078
Basic production code: 0568809
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 351533045069403
IMEI spare to net: 3A 15 35 03 54 60 49 00
IMEI SV to net: 33 15 35 03 54 60 49 30 F0
Master Code: 3525251021
Phone type: RH-122, Software version: 04.30, Language Pack: MR
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-122.ini
Checking path: \
Checking path: \Products\\
Checking path: *.vpl\
No ini files found...
Done!
Email: kimluanmobile@gmail.com
