Kết quả 1 tới 10 của 11
    May 2010
    Mặc định 2700c xin ae giúp cho
    máy lên chữ nokia trắng màn rồi tắt. log em nó đây;
    Phone Type: RM-561 (Nokia 2700 classic)
    SW Version: V 09.98 06-09-10 RM-561 (c) Nokia
    Imei plain: 35337604288912-8
    Product Code: 0579808
    Language Pack:
    - not available.
    This is SL3 phone(Simlock2 format).
    - Avoid SW Downgrade
    & manual erase to this phone !
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 353376042889128
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    đây là log em scan
    DIA_NGUC_MA
    0984745666
    May 2010
    đây là log info; Version Info:
    MCU SW version: V 09.98 06-09-10 RM-561 (c) Nokia
    HW version: 1000
    RFIC version: 06540601
    DSP version: ICPR72_09w26
    LCD version: SEIKO
    PPM version: V 09.98 06-09-10 RM-561 (c) Nokia X
    BT MCM version: 2222-302
    Retu version: 16
    Tahvo version: 22
    Content Pack version: Content: CTV ID v2 V 09.98 06-09-10 RM-561 (c) Nokia
    Bluetooth ID: A0 4E 04 9A E3 BF
    DVB-H receiver Bootloader version: N
    Product Info:
    Production serial number: DAW686331
    Product code: 0579808
    Module code: 0204245
    Basic production code: 0577212
    Long production SN: 0
    Serial Numbers:
    IMEI plain: 353376042889128
    IMEI spare to net: 3A 35 73 06 24 88 19 02
    IMEI SV to net: 33 35 73 06 24 88 19 52 F5
    Other Info:
    Model: Nokia 2700 classic (Classic Phone)
    CS type: GSM850/GSM900/GSM1800/GSM1900
    BSI: 5.3 KOhm
    Counter: 0/3, 0/10
    DIA_NGUC_MA
    0984745666
    Thành viên tích cực BUIVANCHUNG's Avatar
    Kim Anh Mobile Đồng Nai
    flash cho nó phát ver đụng nóc là ok mà,bạn mới info thôi....
    KIM ANH MOBILE:0979528949-Yahoo:satthatkim76
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    vẫn chưa làm thành công con nào nếu lên trắng rồi tắt với 2700c
    nếu tên noki rồi tắt xuống rồi tự khởi động lên lại thì sẽ flash lại ok
    dòng này do lỗi cặp là chính
    May 2010
    em flash xong rồi vẫn thế.
    DIA_NGUC_MA
    0984745666
    May 2010
    cái này đã đụng nóc chưa anh?
    DIA_NGUC_MA
    0984745666
    86 phan đình phùng quảng ngãi
    log đã chạy ver đụng nóc rồi,log infor quá đẹp luôn
    thử backup xóa las rồi nạp lại xem vô menu được không
    thông thường dòng này bị như vậy chỉ có cách thay nguyên cặp hoặc backup rồi thay ic flass
    Thành viên chính thức hieungan's Avatar
    Jan 2009
    đến từ NÚI NHẠN SÔNG ĐÀ ĐÁ CẤM LEO
    dùng phonix
    hieungan mobile 0977503169
    nhấn thanks nếu thấy bài viết có ích
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    cái này thay cặp thì có lý hơn rồi vì log đẹp mà không lên được thì do lỗi cặp chương trình rồi,thử lại cách backup full xóa trắng nạp lại coi bạn hiền
    Thành viên chính thức dainghia132's Avatar
    Aug 2010
    dùng phonex đi đừng làm cứng con này tui chạy = mxkey rồi vẫn trằng lại à
    Nhân từ với kẻ dịch là tàn nhẫn với bản thân __
  1. xin giúp hạ ver 2700c thanks
    By lenhan in forum BB5
    Trả lời: 19
    Bài viết cuối: 08-10-2011, 13:53
  2. 2700c cần anh em giúp
    By thanhphuek in forum BB5
    Bài viết cuối: 05-10-2011, 17:52
  3. Trả lời: 15
    Bài viết cuối: 01-06-2011, 12:30
  4. xin giúp sơ đồ đèn 2700c
    By le quoc vinh in forum BB5
    Bài viết cuối: 10-03-2011, 08:29
  5. các xem giúp e cai log 2700c
    By 012345012345 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 19-11-2010, 15:10
