Kết quả 1 tới 10 của 11
    Thành viên tích cực minhtu2326's Avatar
    Mặc định 2730 contacsevit xin giúp
    em có cây 2730 tự nhiên bị contacsevit chạy pm vẫn không hết xin các bác chi giáo
    Phone Type: RM-578 (Nokia 2730 classic)
    SW Version: V 10.40 27-04-10 RM-578 (c) Nokia
    Imei plain: 35831403805929-4
    Product Code: 0585313
    Language Pack:
    - not available.
    This is SL3 phone(Simlock2 format).
    - Avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 358314038059294
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    đây là log trên hộp mxkey
    đây là log trên jaf
    Asic ID: 000000010000022600010006030C192101023000
    Asic Mode ID: 00
    Asic EM ID: 00000B22
    Asic Public ID: 09C0000497548D5690942CDC9252142405BA5826
    HASH: 9DDBFCFE6E73CED7D8C6268C8EB8572300000000
    ROM ID: 273F6D55DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 09.0B.01 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 89820089 <=> INTEL -> Type not in database
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 09.2F.00 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 10.40
    27-04-10
    RM-578
    (c) Nokia
    HW version: 2000
    PCI version:
    RFIC version: 17141716
    DSP version: ICPR72_10w01_Tommy
    LCD version: SEIKO
    PPM version: V 10.40
    27-04-10
    RM-578
    (c) Nokia
    V
    BT MCM version: 2.31-SP2.26
    Retu version: 16
    Tahvo version: 22
    Production serial number: DNL851766
    Product code: 0585313
    Module code: 0204322
    Basic production code: 0580665
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 358314038059294
    IMEI spare to net: 3A 85 13 04 83 50 29 09
    IMEI SV to net: 33 85 13 04 83 50 29 59 F8
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-578.ini
    Setting local mode...
    Reading product code...
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-578\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-578\
    No ini files found...
    Done!
    Jan 2010
    Quan Họ - Bắc Ninh
    Bạn thử Check em USB này coi sao
    bỏ em này đi ah các bác
    Jan 2010
    Quan Họ - Bắc Ninh
    Trích Được post bởi minhtu2326 Xem bài viết
    replace = thay thế :rolleyes: Kứ thế mà test
    em thay thế rồi sao vẫn không được vậy còn cách nào không hả các bác
    sao kô bác nào giúp em vậy
    Thành viên tích cực QuocAnh_1985's Avatar
    May 2011
    Quê hương của Núi Nhạn_Sông Đà
    khởi động lên bị hay bấm khởi động k cần sim mới bị anh.
    Thành viên chính thức bacson_langson's Avatar
    Oct 2010
    thay betty là hêt liên...
  1. 1200 bị contacsevit cần giúp
    By thuongmobi5 in forum DCT4 - WD2
    Bài viết cuối: 10-03-2013, 12:57
  2. 3500c contacsevit xin giúp.
    By mjnhtuan123 in forum BB5
    Bài viết cuối: 29-02-2012, 15:46
  3. 1202 bị contacsevit cần ace giúp đỡ
    By binhmob in forum DCT4 - WD2
    Bài viết cuối: 26-10-2011, 21:03
  4. 1650 contacsevit cần giúp đỡ
    By thangyb123 in forum DCT4 - WD2
    Bài viết cuối: 05-08-2010, 16:30
  5. 1202 contacsevit cần giúp
    By cuongmobile.vn in forum DCT4 - WD2
    Trả lời: 15
    Bài viết cuối: 12-07-2010, 13:10
