Thông tin Update mới từ HWK
Đây là thông tin cập nhật sắp tới của Saras=hwk,danh sách này không phải là danh sách update cuối cùng và có thể sẻ update thêm nhiều model nửa trước khi có bản cập nhật mới .Vui lòng không hỏi thời gian khi nào có bản update mới, khi tôi chưa công bố thời gian.
DCTxBB5
1. BB5 products: RM-576,RM-577 (6700s,6700s-1c) added.
2. Local RPL Service Fixed for ASIC 2,5,6,7,11 (UEM_PASW is Correct now)
Note: Need Confirm [Readout and Use UEM IMEI] when do [Rd UEM].
3. [Check Ask/Rpl] Renamed to [Calc Ask/Rpl] as can Calculate RPL now.
4. [Calc Ask/Rpl] Function will Generate Real RPL from ASK file (ASIC 2,5,6,7,11)
Note: When Reading UEM, do not Forget Set Right [UEM Changed] Status !
5. RSA Lock/Unlock for All DCT4+ products (not need Patch)
6. Life Timer added to [PM Edit]
7. DCT4 INFINEON Based Products USB Flashing / UI support added:
RH-111,RH-125,RH-126,RM-607,RM-608,RM-643,RM-644,RM-647,RM-653,
RM-669,RM-689,RM-704,RM-732,RM-733 (1202,1616-2,1616-2b,C1-01,C1-01.1,
C1-02,C1-02.1,1280,1800,1800b,C1-00,C2-00,X1-00,X1-00.1)
8. BB5 RAP3Gv40 Based Products USB Flashing / UI support added:
RM-509,RM-510,RM-511,RM-540,RM-598,RM-604,RM-615,RM-638,RM-721,RM-722
(3710a-1,3710a-1c,3711a-1,X3-00,7230-1c,7230-1,5330-1d,6303ci,C2-01,C2-01.5)
9. BB5 RAPU Based Products USB Flashing / UI support added:
RM-582,RM-596,RM-601,RM-609,RM-610,RM-627,RM-629,RM-632,RM-634,
RM-639,RM-640,RM-645,RM-648,RM-658,RM-659,RM-662,RM-675,RM-682,
RM-688,RM-691,RM-697,RM-699,RM-707,RM-718,RM-719,RM-720,RM-749
(Vertu CQ,N8-00,C6-01,E6-00,E6-00.1,X5-01,5230-1d,E5-00,E5-00.2,X3-02,C3-01,
C5-00.X5-01.2,E73,X7-00.1,C3-01m,C7-00,6702s,C5-00.1,C7-00b,C5-03,E5-00m,
X7-00,C6-01.3,C5-03.2,C5-04.1,C7-00s)
10.BB5 RAPIDO Based Products USB Flashing / UI support added:
RM-484,RM-485,RM-486,RM-551,RM-552,RM-559,RM-588,RM-593,RM-594,
RM-612,RM-624,RM-625,RM-684
(N86-1,N86-3,N86-5,X6-00.1,X6-00m,X6-00,5230-1,5230-1c,5230-1b,C6-00,
C6-00.1,5288,5250)
11.BB5 JUNO (BCM21351) Based Products USB Flashing / UI support added:
RM-497,RM-586,RM-614,RM-618,RM-709,RM717
(7020a-2,2710c-2,C3-00,X2-00,X2-01,X2-01.1)
LG_GSM
1. Infineon:
A110,A130,A133,A133GO,C100,C105,C300,C300GO,C305,C 310,GB220,
GB220nGO,GB230,GB280,GD350,GD510,GD510N,GM360,GM36 0i,GM600,
GS170,GS290,GS290GO,GS290N,GS390GO,GS500,GS500g,GS 500gx,GS500v,
GT350,GT350GO,GT350i,GT360,GT365,GU220,GU230,KF510 ,KF510d,
KM380,KM380c,KM380d,KM385d,KM386c,KP500,KP500N,KP5 01,KP502,
KP502GO,KP505,KP550,KP570q,KS360,KS365,T300,T310,T 310i,T310N,
T315,T315i,T320,T320e,T320g,T325 added.
Notes:
1. To See Unlock Codes and Instructions, Press [BOOT]
2. To Flash Dead Phones, Tick [Emerg. Boot]
2. MTK A120,A155,A160,A165,GB161 added.
3. BT Address Write Added for Infineon and MTK platforms.
SAMs
TRIDENT
A127,i626,X475 added (DUNL,IM,FL)
OM(SYSOL)
T209,T319 added (DUNL,IM,FL,SECT)
SWIFT
A436,A437 added (DUNL,IM,SECT)
Note: For Flashing use A4xxxx_RD files.
A516,A517,T229,T249,T339,T349-LTA-USA,T369,T409,T619,T739
added (DUNL,IM,SECT,FL)
Added Multi Drive support for TFS Read.
SWIFT-AEROFONE
Added [Patch MSL] Function to Patch without MCU Part Flashing.
T109,T119 added (DUNL,IM,FL)
E1080F-IND-MEA-SEA,E1081T-EU-IND-MEA-SEA,E1085F,E1085F-MEA,
E1105F,E1150i,E1160i,E1170T,E1172,E1175T-EU-IND,E1178,E1225F,
E1225T,E1225T-IND added (PUNL,PIM,FL)
Notes:
1.Mixing of EU IND MEA SEA Files causes Blinking or Dead Sets.
2.E1081T EU E2P Image is not Compatible with IND, MEA or SEA.
3.For Cross Flashing Select Model Name Extension by File type.
4.Before Unlock, Info to see Codes or Rebuild IMEI use
[Patch MSL] Button or Flash with [Patch MSL] Option Enabled.
C3222 added (DUNL,CUNL)
Note: C3222 Flashing not Supported yet, use Original Flasher.
SWIFT-3G
C5010E,E3210 added (CUNL,SECT,FL)
QUALCOMM
A847,A927,B2710D,C5180,S5520,S5580,S6700T,S6888,T3 59,T479,T749 added.
More Versions Support of Hidden Sysinfo models CUNL and UNFR:
A706,A707,A717,A727,A847,A887,A897,A927,B2710,B271 0D,S3370,
S5530,T359,T469,T479,T559,T659,T749
QUALCOMM+LSI
S8500B,S8530 added (FL)
BROADCOM
S5230N added (FL,CUNL,UNFR,BRP)
S5330L,S5750E,S5753E,S7230E,S7233E added (FL)
S5250,S5253,S5330,S5330L,S5333 Boot Repair (BRP)
INFINEON
B3310i,C3200,C3200G,C3200L,C3530,C3530L,E2530,S331 0i,S3350,
S3353,S3550,S3550C,S3550L added (CUNL,PUNL,PIM,FL)
E1151, Now Possible to Flash Read BIN Dump (Size: 007F0000)
Regards,
Odia.
