các bác xem giúp em log nay em đã xóa tool nạp lại toàn bộ nhưng vẫn thế đây là log em vừa nif
MCU ID: 0x2292
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.91
27-03-09
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w31_UPP
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 5.91
27-03-09
RH-99
(c) NMP
MR
ADSP SW version: V 5.91\n27-03-09\nRH-99\n(c) NMP\nmr
Production serial number: IER520684
Product code: 0574499
Module code: 0203402
Basic production code: 0571402
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 358626014748248
IMEI spare to net: 3A 85 26 06 41 47 28 04
IMEI SV to net: 33 85 26 06 41 47 28 74 F0
Master Code: 7434106064
Phone type: RH-99, Software version: 5.91, Language Pack: MR
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Setting local mode...
Reading product code...
Product Code: 0574499
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\\Products\RH-99\
No ini files found...
Done!
