các a giúp e với .e thay 1 bộ nguồi +flash xong chạy pm thi imei?????.em mới vào nghề chưa biết cách làm ae chỉ giáo cho e với.thanks
MCU ID: 0x2292
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: \Products\RH-99\
No ini files found...
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99_dp_v_29_10_MCUSW5_51\rh99_05.510
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99_dp_v_29_10_MCUSW5_51\rh99_05.51mr
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99_dp_v_29_10_MCUSW5_51\rh990_nai5.51mr
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99_dp_v_29_10_MCUSW5_51\rh99_05.510
Booting phone...
MCU ID: 0x2292
Loader version: 04.4A.00 -> Revision: 0007
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4C30; Loader chk: 39
Loader is ready...
MSID: 84697D5245185C77023F538B02
MSID decoded: 3E4EBAE90007250EA8000000
FAID: 62A50A3FADD7ED7EE935CE5A
Erasing...
Found 5 interval(s) to erase
Operation took 1 minutes 9 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 15 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-99_dp_v_29_10_MCUSW5_51\rh99_05.51mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84B02BC65BED41205DBDC57753
MSID decoded: 3E4EBAE90007250EA9000000
FAID: 74451B3ABD5AD0F4D3CD6CEA
Operation took 0 minutes 6 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Operation took 0 minutes 22 seconds...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-99_dp_v_29_10_MCUSW5_51\rh990_nai5.51mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 24 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-99, Software version: 5.51
IMEI: ???????????????
Product Code: 0546885
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Done!
Done!
Done!
Connecting to phone...
Imei need to be 14 digits in length...
