e nhận 1 cây 7210c bật nguồn lên chữ nokia rồi treo trắng màn hình đứng máy luôn . e da read file rpl va pm 308 > xóa full>nap FW chuẩn > Write : RPL>Write : pm308 >SX4 >write pm full . vẫn không được va mxkey báo như thế này ae xem giúp e với ..
MXKEY Serial: [FT SCR2000 0] - C085367A
Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0
Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011)
Processing MCU file: rm436__07.23.mcusw
[BB5,BB5 ALGORITHM] size: 18.06 MB
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 09A0010C0EF058504D0A466D1C8EAD48FDD28585
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
TransmissionMode: DDR&TX2
Erase size: 19.12 MB
CMT NOR area [00000000-000006BF] erased in 0.704 s
CMT NOR area [000006C0-0001FFFF] erased in 0.140 s
CMT NOR area [00040000-000BFFFF] erased in 2.875 s
CMT NOR area [000C0000-0013FFFF] erased in 0.203 s
CMT NOR area [00140000-0119FFFF] erased in 1 min 26.359 s
CMT NOR area [011A0000-0133FFFF] erased in 9.094 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 (RAP Certificate 142 v.1) sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 2 min 13.157 s
Processing PPM file: rm436__07.23.ppm_v
[BB5,BB5 ALGORITHM] size: 7.68 MB
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 8.62 MB
CMT NOR area [01340000-01BDFFFF] erased in 2.031 s
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x01AC0000, Result: 0010
Task failed at (0800001C)!!!
Last RX buffer: C7 01 2D 01 03 CD 00 00 10 00 00 00 F1 72
