tình hinh là mới nhận em 6020 nhận cuộc gọi mất nguôn chưa biết làm từ đâu nhờ ae tư vấn
log check và info em nó
Getting MCU ID
MCU ID: 0x2142
FLASH ID0: 882E0020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 04.90
09-05-06
RM-30
(c) Nokia.
HW version: 5051
PCI version:
UEM version: 400
UPP version: 8514
RFIC version: 0205
DSP version: P05w06.v34
LCD version: AMAZON
PPM version: V 04.90
09-05-06
RM-30
(c) Nokia.
V
Production serial number: MKJ539949
Product code: 0534887
Module code: 0202357
Basic production code: 0522363
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: m????????????????????????????????????????????????
Default SN type: m????????????????????????????????????????????????
IMEI plain: 359772009898751
IMEI spare to net: 3A 95 77 02 90 98 78 05
IMEI SV to net: 33 95 77 02 90 98 78 15 F4
Master Code: 4272402771
Phone type: RM-30, Software version: 04.90, Language Pack: V
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-30.ini
Setting local mode...
Reading product code...
Product Code: 0534887
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-30\
Checking path: \Products\RM-30\
No ini files found...
Done!
úng dụng Ibox đó nha
