    PHÚ ĐIỀN-TÂN PHÚ-ĐỒNG NAI
    Mặc định ae xem giúp log 2760
    1st Boot: Ok, DCT4, UPP: 3162 [Rm-258] [2.2.0.0]
    2nd Boot: u3_2nd.fia, Ver: 4.79.0
    Fl0: 0x01000000-0x02FFFFFF,00EC2208,Sam K8F5615ETM
    Algorithm: u3_amd.fia, Ver: 4.79.0
    Algorithm Ok, MSID: 842A71670EFE2BB699109E40A9
    Decoded MSID: 2C40BAE9-00D2B53D-A8000000
    Encoded FAID: 75E83F63-4C631A50-2AD2640F
    IMAGE: rm258__07.60.mcusw
    Erasing: 0x01000000-0x0101FFFF ...
    Erasing Error: 10, at: 0x01000000-0x0101FFFF, 940203, Time: 00:00
    máy bị mất nguồn đã thay cpu nguồn flash nhưng khj chạy phần mềm máy vẫn báo lỗi này
    Thành viên kỳ cựu setot_thoi's Avatar
    Sóc Trăng
    Trích Được post bởi nhathuy_mobile2009 Xem bài viết
    kiểm tra lại con UPP . thân
    MẩnMobile .Y/H : Jimmyphong10
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    cho sàg jasp flash coi sao bạn . tiện vệ sinh lun cáp và main . rồi quăng cái log lên
    yahoo: viethuy_mobi
    cpu em đã thay 3 con rùi ,nguồn và flash cũng đã thay 2 em nhưng chạy lúc nao cũng báo vậy ,
    Getting MCU ID
    MCU ID: 0x3162
    FLASH ID0: 220800EC <=> SAMSUNG (SEC) -> K8F5615ETM/K5G5629ATD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    First 16 bytes: AD 7E 96 07 00 FF 10 40 00 00 00 00 00 00 00 00
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-258\rm258__07.60.mcusw
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-258\rm258__07.60.ppm_v
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-258\rm258__07.60.image_v
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-258\rm258__07.60.mcusw
    Booting phone...
    MCU ID: 0x3162
    Boot size is 0x09A8
    Boot is ready...
    FLASH ID1: 220800EC <=> SAMSUNG (SEC) -> K8F5615ETM/K5G5629ATD Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11
    Flash ID is 0x0822EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
    Loader size is 0x7528; Loader chk: a2
    Loader is ready...
    MSID decoded: 2C40BAE900D2B53DA8000000
    FAID: 75E83F634C631A502AD2640F
    Operation took 0 minutes 6 seconds...
    Erasing...
    Found 2 interval(s) to erase
    Erasing area: 01020000 - 01C3FFFF...
    Error erasing area: 01060000 - 0107FFFF
    đây là log của JAF
    theo em nghĩ thì chắc ko phải tại cpu ,flash hay nguồn vì em lấy 1 bộ của cây lên nguồn bình thường sàng qua thì o nhưng chạy phần mềm vẫn báo lỗi này ,nhưng lại bị hao nguồn ở chế độ chờ và camera kko hoạt động được vì cpu bị lỗi .
    dòng dct4 thì làm nguồn ko mấy gì là khó nhưng thật sự e bó tay với cây này
  1. 2760 liệt phím cần giúp !
    By hà_vũng tàu in forum DCT4 - WD2
    Bài viết cuối: 19-07-2011, 09:06
  2. 2760 cần anh em giúp
    By longseven in forum DCT4 - WD2
    Bài viết cuối: 31-10-2010, 12:02
  3. 2760 bị liệt phím giúp..
    By vipiphone in forum DCT4 - WD2
    Bài viết cuối: 03-07-2010, 12:00
  4. 2760 cần giúp
    By hung_nokia in forum DCT4 - WD2
    Bài viết cuối: 02-09-2009, 10:48
  5. giúp em con màn hình 2760
    By toilatoi83 in forum DCT4 - WD2
    Bài viết cuối: 30-10-2008, 22:02
