Kết quả 1 tới 10 của 19
    Thành viên kỳ cựu madao's Avatar
    Mặc định 6500 có vấn đề khi flash cần giúp đỡ
    Mình mới nhận cây 6500s(rm240) chỉ lên trắng màn hình rồi tắt mình cho vào MxBox thì k nó chạy chỉ đến đoạn write PPM thì bị đơ luôn rồi báo lỗi. Đây là log khi chạy
    MXKEY Serial: [MxKey HTI FLASHER INTERFACE 3] - C085510E
    Using device: HTI BOX, FW ver: 00.07
    Driver: uhci:hub:ccgp:HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0
    Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
    EM0 ID: 00000295
    EM1 ID: 00000B22
    PUBLIC ID: 2A20010D2D960254A1EC10BC7F5BECF19EAE6EA0
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
    Storage0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: A69838E8C5F20150E64E2E6E06DE6E50B26B593F
    TransmissionMode: DDR&TX2
    Processing MCU file: rm240__09.40.mcusw
    [BB5,BB5 ALGORITHM] size: 20.36 MB
    Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
    Erase size: 21.87 MB
    CMT FLASH,NOR area [00000000-0001FFFF]
    CMT FLASH,NOR area [00040000-000BFFFF]
    CMT FLASH,NOR area [000C0000-0013FFFF]
    CMT FLASH,NOR area [01480000-015FFFFF]
    CMT FLASH,NOR area [00140000-0147FFFF]
    erased in 48.282 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: A69838E8 [RAP Certificate 84 v1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 1 min 57.719 s
    Processing PPM file: rm240__09.40.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.34 MB
    Erase size: 6.75 MB
    CMT FLASH,NOR area [01600000-01CBFFFF]
    erased in 15.140 s
    Programming completed in 39.297 s
    Processing CNT file: rm240__09.40_ism_016.image_v
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.89 MB
    Erase size: 34.87 MB
    CMT FLASH,NOR area [01FC0000-03F9FFFF]
    CMT FLASH,NOR area [01CC0000-01FBFFFF]
    erased in 1 min 3.500 s
    Error while programming [00] at 0x01FF0000, Result: 0000
    còn đây là log khi bus check
    CMT Data :
    EM0 ID: 00000295
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Original Imei: 35354702451208
    Original Product code: 0549750
    Bluetooth ID: 00210843EB87
    Phone not responding !
    Thành viên mới hong hinh quyen's Avatar
    Jun 2011
    chac chet wua
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    chuyển box khác flash cho nó lên đi anh
    mình đưa qua jaf thì em nó ko đồng bộ được
    con đây là lock chạy của jaf nhờ ace coi giùm
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-240\
    Checking path: \Products\RM-240\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__09.40.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__09.40.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__09.40_ism_016.image_v
    Languages in ppm: English,Chinese Simpl,Chinese T,Vietnamese
    Changing flashing settings...
    Manual mode selected, version can't be checked!
    Booting phone...
    FAST PHONE detected!
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101003000
    Asic Mode ID: 00
    Asic EM ID: 00000B22
    Asic Public ID: 2A20010D2D960254A1EC10BC7F5BECF19EAE6EA0
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 09.0B.01 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 003F0001 <=> SPANSION -> Type not in database
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 09.2F.00 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Erasing...
    Operation took 0 minutes 49 seconds...
    Writing...
    Stage 1
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    Sending CMT PUB KEYS...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Stage 1
    FAST MODE finish!
    Operation took 2 minutes 31 seconds...
    Reseting phone...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__09.40.ppm_v
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Erasing...
    Writing...
    Stage 1
    Operation took 0 minutes 45 seconds...
    Reseting phone...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__09.40_ism_016.image_v
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Erasing...
    Operation took 0 minutes 27 seconds...
    Writing...
    Stage 1
    Operation took 1 minutes 39 seconds...
    Reseting phone...
    Done!
    Total time: 6 Minutes, 35 Seconds
    DCT4/BB5 counter: 485
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    dòng này nhiều lúc không đồng bộ nhưng vẫn lên nguồn ok
    nếu máy đã lên nguồn thì cắm sạc để 30p rồi cho vào đồng bộ lại
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    bỏ 2 dấu backup . di a chạy thử đi a
    yahoo: viethuy_mobi
    Dec 2008
    Phù Tiên
    Chạy thử USB đi .
    Next Level 99,9
    anh em đâu cả rồiii
    vào giúp mình một tay. đang ăn trái bí !!!!!!!!!!!!!!
    mông ace nhiệt tình giúp cho thanks
    giờ em nó vẩn như trước. & đả bỏ 2 dấu tic + chạy từng file một nhưng em nó vẩn cứ iiiiiiiiiiiiiiiiiiiiiii ra
    Thành viên mới vuongtoanviet's Avatar
    Trích Được post bởi madao Xem bài viết
    Đem qua USB chạy đi bạn ơi
  1. xin hướng dẫn FLASH 6500 dead usb bang box ATF
    By nguyenduymy in forum Advance Turbo Flasher
    Bài viết cuối: 29-02-2012, 14:52
  2. 6500 flash bằng usb die!
    By anhquanmobile in forum BB5
    Bài viết cuối: 15-07-2010, 23:33
  3. 6500 cần giúp
    By mr.kent in forum DCT4 - WD2
    Bài viết cuối: 21-09-2009, 09:24
  4. 6500 cần giúp
    By binhmobile1979 in forum Máy Trung Quốc
    Bài viết cuối: 10-04-2009, 08:37
  5. Trả lời: 0
    Bài viết cuối: 04-11-2008, 11:43
