mình mới nhận 1 con 2700 bật nguồn báo contact service rồi tắt nguồn luôn.giúp mình với
bots cái log bằng mxkey lên anh
làm con ic nguồn good
anh thử đi
mình info nó báo thế này
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
USB Cable Driver version: 7.1.36.0
Changing mode...Done!
Booting phone...
FAST PHONE detected!
CMT Boot Data:
Asic ID: 000000010000022600010006030C192101033000
Asic Mode ID: 00
Asic EM ID: 00000B22
Asic Public ID: 1E10020AE75A0056AB131573D8E5AFC37A79795E
HASH: 9DDBFCFE6E73CED7D8C6268C8EB8572300000000
ROM ID: 273F6D55DFAAF68F
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 240000EC <=> SAMSUNG (SEC) -> Type not in database
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 09.98
06-09-10
RM-561
(c) Nokia
HW version: 2000
PCI version:
RFIC version: 06540601
DSP version:
ICPR72_09w26
LCD version: SHARP
PPM version: V 09.97
18-06-10
RM-561
(c) Nokia
V
BT MCM version: 2222-302
Retu version: 16
Tahvo version: 22
Content Pack version: Content: ctv_nz_grey
V 09.98
06-09-10
RM-561
(c) Nokia
Production serial number: ICS829625
Product code: 0588814
Module code: 0204245
Basic production code: 0577212
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 353376044863576
IMEI spare to net: 3A 35 73 06 44 68 53 07
IMEI SV to net: 33 35 73 06 44 68 53 57 F5
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-561.ini
Checking path: C:\Program Files\Nokia\Phoenix\Products\\
Checking path: \Products\\
No ini files found...
Done!
mình chạy băng jap thôi
anh có MXKEY buzcheck pos cái log lên cho dể phát hiện ra là DO HW hay HW anh á ,, còn JAF thì thấy log vẩn đẹp bình thường Là DO HW đó anh
ae cho hoi q24 tiep xuc sac dien kem ,ạ lam qua rui chi rum voi
lúc anh mở nguồn lên máy hỏi khởi đông không cần sim anh nhấn ok thì nó báo CS hay là anh mổ nguồn lên thì nó báo Luôn CS ko hỏi khởi động ko cần sim vậy anh .. cho them chút thông tin nha
chạy v cao hơn đi xem thế nào
nếu như anh không lắp thẻ sim mà bật nguồn lên báo không có thẻ sim chập nhạn rồi báo cs thì con ic nguồn
