    Thành viên tích cực sonfa139's Avatar
    May 2011
    Mặc định 1110i cần giúp
    mình có con 1110i đang dùng tự nhiên tự khởi động lại,được 1 lúc la mất nguồn luôn,mình chạy thử bằng JAF va có log như thế này,nhờ ae xem giúp. FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
    Checking path: C:\Program Files\Nokia\Phoenix\Products\Products\RH-93\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02qa
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02qa
    Languages in ppm: English,Chinese S,Chinese T
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02ma
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02ma
    Languages in ppm: English,Chinese S,Chinese T,Vietnamese,Filipino
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    First 16 bytes: 89 4A B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
    Flash ID is 0x7E2A0100
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: c6
    Loader is ready...
    MSID: 846C6D3BEBDDE5F7AB67734628
    MSID decoded: 3E4EBAE900492AB2AA000000
    FAID: 9AB9BBD8F71E9B8C3E4119F2
    Operation took 0 minutes 6 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 28 seconds...
    Writing...
    Error cmd: 14!
    Addr: 01020
    Moderator LocPhatBacLieu™'s Avatar
    Apr 2011
    Bạc Liêu
    Bạn đem wa HWK nạp lại cho nó là ok thôi.
    May 2010
    ĐIỆN BIÊN
    bạn cho thêm thoong tin đi.máy làm sao.nhình cái log trên thì có lẽ cpu có vấn đề
    TRUNG HIẾU MOBILE
    Thành viên chính thức quangtham_yb's Avatar
    yên bái
    Mặc định sam sung e1081t mat mich can cac anh em gup
    em moi nhan con sam sung e1081t mat mic em da thay het cac quan day va tu tro duong mich ma van ko duoc ai ngap roi gup em voi em cam on ,thong cam vi may em khong viet duoc dau
    Thành viên tích cực VH-Mobile's Avatar
    Đà Lạt
    cai nay minh nghi là CPU rùi bạn ơi máy co bị tắm biển ko vậy?
    0967-225-468
    Moderator Dong_Mobile's Avatar
    Nov 2010
    Trích Được post bởi sonfa139 Xem bài viết
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing...
    Writing...
    Error cmd: 14!
    Addr: 01020
    mang qua box khác đi bạn.không được múc UPP.
    Trích Được post bởi quangthammobile Xem bài viết
    lập ther khác đi anh.
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    thay cáp đổi box khác luôn không thì đụng cứng rồi bạn
    May 2011
    lúc đầu máy thỉnh thoảng trắng màn,có lúc tự khởi động lại,sau đó tắt nguồn luôn
    May 2011
    máy này là hàng tàu,nhưng main giống như hàng xịn
  1. 1110i cần giúp
    By trung83 in forum DCT4 - WD2
    Bài viết cuối: 07-11-2009, 15:45
  2. 1110i can giúp
    By rap_3g in forum DCT4 - WD2
    Bài viết cuối: 04-10-2009, 12:51
