1208 rơi nước vệ sinh xong không lên, chô vào bõ check ok nhưng không infor được. đây là log fash nhờ ae xem giúp. mình đã lắc cpu. nguồn.
Getting MCU ID
MCU ID: 0x2292
FLASH ID0: 260600EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: D:\DT\PMDT\JAF\RH 105\1208_RH_105_v37.0_sw05.91ppmMR\1208_RH_105_v37 .0_sw05.91ppmMR\rh105_05.910
Phone Type:
PPM Flash file: D:\DT\PMDT\JAF\RH 105\1208_RH_105_v37.0_sw05.91ppmMR\1208_RH_105_v37 .0_sw05.91ppmMR\rh105_05.91mr
Phone Type:
CNT Flash file: D:\DT\PMDT\JAF\RH 105\1208_RH_105_v37.0_sw05.91ppmMR\1208_RH_105_v37 .0_sw05.91ppmMR\rh1050_nai5.91mr
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: D:\DT\PMDT\JAF\RH 105\1208_RH_105_v37.0_sw05.91ppmMR\1208_RH_105_v37 .0_sw05.91ppmMR\rh105_05.910
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x0626EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: 3a
Loader is ready...
MSID: 84D4771BE5D262CE9FBA73A256
MSID decoded: 3E4EBAE90028A150A8000000
FAID: 3D37294ADE097541714C7A7D
Erasing...
Found 5 interval(s) to erase
Operation took 0 minutes 23 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: D:\DT\PMDT\JAF\RH 105\1208_RH_105_v37.0_sw05.91ppmMR\1208_RH_105_v37 .0_sw05.91ppmMR\rh105_05.91mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Writing...
Restarting MCU...
CNT: D:\DT\PMDT\JAF\RH 105\1208_RH_105_v37.0_sw05.91ppmMR\1208_RH_105_v37 .0_sw05.91ppmMR\rh1050_nai5.91mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84AAE60C47244F795B611957F2
MSID decoded: 3E4EBAE90028A150AA000000
FAID: 12C3549DECC83D61354F23AD
Erasing Content Pack...
Found 1 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 10 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
