Kết quả 1 tới 10 của 14
    Thành viên chính thức buidinhthu's Avatar
    Mặc định các sư phụ chỉ em với 3110c bị contacsive
    máy của em bật nguồn lên cotacsive rồi tất nguôn luôn. anh em nào sửa rồi chì em với .... thanks.MXKEY Serial: [FT SCR2000 0] - C08202B3
    Using device: POTATO BOX, FW ver: 01.B1
    Driver: usbuhci:usbhub:FTDIBUS, ver: 2.0.0.0 , NTMP ver: 2.8.14.0
    Module ver: 1.0.0.17841(12-07-2011), Library ver: 1.0.0.11875(12-07-2011)
    Processing MCU file: rm237__07.21.mcusw
    [BB5,BB5 ALGORITHM] size: 14.48 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 06A0000761EA7D56ADC72FC9AF93A8D41350E2AD
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    Storage0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00020000-0007FFFF]
    CMT FLASH,NOR area [00080000-000DFFFF]
    CMT FLASH,NOR area [00100000-001FFFFF]
    CMT FLASH,NOR area [00200000-0031FFFF]
    CMT FLASH,NOR area [00320000-0105FFFF]
    CMT FLASH,NOR area [01060000-01067FFF]
    CMT FLASH,NOR area [01068000-0107FFFF]
    erased in 1 min 29.329 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    Programming completed in 5 min 4.563 s
    Processing PPM file: rm237__07.21.ppm_v
    [BB5,BB5 ALGORITHM] size: 4.35 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 4.62 MB
    CMT FLASH,NOR area [01080000-0151FFFF]
    erased in 26.250 s
    Programming completed in 40.234 s
    Processing CNT file: rm237__07.21.image_v
    [BB5,BB5 ALGORITHM] page size: 64 K size: 5.01 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 10.75 MB
    CMT FLASH,NOR area [01520000-01FDFFFF]
    erased in 1 min 20.812 s
    Programming completed in 44.906 s
    Total time for flashing process(boot+erase+write) was 11 min 5.719 s
    Phone not responding !
    Thành viên tích cực chithang8xx's Avatar
    quăng cái log info lên đi bạn.
    Dịch Vụ Hot :Nhận Update FW,TestPoin,Quét pinout,Unlock,Reset Code các pé từ 16t ==> 20t.bảo hành dài hạn,không tác dụng phụ:D:D:D
    Thành viên kỳ cựu madao's Avatar
    bạn nói rỏ hơn đi
    bật nguồn bị contac liền hay bỏ sim vào mới contac vậy bạn
    nếu ko sim bật nguồn bị contac thì bạn nên coi lại phần cứng nha bạn
    Thành viên chính thức htmobile_krongpa's Avatar
    Mar 2011
    làm ic nguồn trước xem sao bạn
    sao ko co bác nao giúp em vạy
    ko inffo dược mấy anh oi
    Thành viên chính thức nghiabt's Avatar
    Trích Được post bởi buidinhthu Xem bài viết
    ném cái log lên di ae xem giúp cho
    Mar 2011
    thế thì làm con nguồn đi, chờ gì nữa
    May 2010
    ĐIỆN BIÊN
    toàn là mấy pro ko à hiện tại máy chết rồi còn đâu mà info.bây giờ chủ thear chạy ver 7.30 là lên sau đó info gì thì info nhé.xong cho cái log lên bạn nhé
    TRUNG HIẾU MOBILE
    V.I.P anhvanmobi's Avatar
    đúng vậy. trước tiên phải nâng ver lên V 7.30 xem máy có lên nguồn đc ko đã. chưa gì đã đòi thay IC nguồn với lại info. nguy hiểm quá, nguy hiểm quá
  1. xin giúp 2690 contacsive
    By lethanhtam92 in forum BB5
    Trả lời: 16
    Bài viết cuối: 21-06-2013, 09:42
  2. xin giúp 1202 contacsive
    By lethanhtam92 in forum DCT4 - WD2
    Bài viết cuối: 08-06-2012, 20:06
  3. LOG 3110c bi loi
    By huynhsoldtdd in forum BB5
    Bài viết cuối: 22-02-2011, 09:16
  4. 3110c cap cuu
    By VŨ PRO in forum BB5
    Bài viết cuối: 29-07-2009, 12:59
  5. 3110c cap cuu
    By phuonganhmobile in forum BB5
    Bài viết cuối: 29-07-2009, 11:51
