Tinh hình la tôi nhận con 7610 đang dùng thì bị sập nguồn,bật lại màn hình trắng lên khoảng 3 giây lại tắt,chạy lại phần mềm bằng MX,HWK,JAFvẫn vậy.Tôi quăng cái log anh em xem hộ phát
MXKEY Serial: [FT SCR2000 0] - C08411FE
Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0
Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011)
Rpl backup already exist (C:\mobileEx\3.4\data\backup\35707000685190_BACK.r pl).
Processing MCU file: RH51_52_67_68PE605220.C1
[WD2 BT2,WD2 ALGORITHM] size: 24.51 MB
Supported Ids: 0082, 1081
ASIC ID: 0x1081 [UPP_WD2 ver: 3.1]
SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8
Supported Ids: 1080, 1081
FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF
FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA
Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50
UEM ID: 008D9B0D:2984DA7E
Area [00000000-0000FFFF] erased in 0.484 s
Area [00010000-00FFFFFF] erased in 1 min 54.391 s
Area [02000000-0287FFFF] erased in 1 min 0.531 s
Area [02FC0000-02FEFFFF] erased in 1.390 s
Flash programming ...
Programming completed in 6 min 6.328 s
File Processed in 9 min 24.172 s
Processing PPM file: RH51_52_67_68PE605220.01
[WD2 BT2,WD2 ALGORITHM] size: 2.68 MB
Area [00000000-0000FFFF] erased in 0.485 s
Area [02A00000-02C9FFFF] erased in 18.531 s
Programming completed in 40.141 s
File Processed in 1 min 17.344 s
Total time for flashing process(boot+erase+write) was 10 min 41.516 s
Phone Type: RH-51 (Nokia 7610)
SW Version: V 2005_wk21 27-05-05 RH-51 (c) Nokia.
Imei plain: 35707000685190-3
Product Code: 0514521
Cellular System: GSM
ASIC ID: 0x1081, type: 5
Language Pack:
- not available.
Imei net: 35707000685190
Version: SIMLOCKLIB VERSION 2.29
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000005
			 Anh em ngó hộ con 7610
