e vừa nhận khách một cây 2700 khởi động lên dùng đc khoảng 30 giây là nó cứ trắng màn và khởi động lại .e đã chạy lại và làm chân đóng lại nhà lầu rồi ma vẫn ko ok cái log của e nó đây nhờ các bác xem hộ em
Version from phone: 09.98
Version from file: 09.98
MXKEY Serial: C0843E1B
Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011)
Reading Important data ...
Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35337604280005_BA CK.rpl).
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0C80011733B14950607207236D32DC649DAA2072
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,CMT
TransmissionMode: 16Bit
TransmissionMode: DDR&TX2
Processing MCU file: rm561__09.98.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
Erase size: 21 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00040000-000BFFFF]
CMT NOR area [000C0000-0013FFFF]
CMT NOR area [00140000-0137FFFF]
CMT NOR area [01380000-0151FFFF]
erased in 1 min 19.094 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100746865 (RAP Certificate 202 v.1) sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 12 min 26.219 s
Processing PPM file: rm561__09.98.ppm_u
[BB5,BB5 ALGORITHM] size: 6.63 MB
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF]
erased in 29.328 s
Programming completed in 4 min 36.812 s
Processing CNT file: rm561__09.98.image_ctv_thai_black
[BB5,BB5 ALGORITHM] page size: 128 K size: 10.89 MB
Erase size: 34 MB
CMT NOR area [01DC0000-0215FFFF]
CMT NOR area [02160000-03FBFFFF]
erased in 2 min 0.078 s
Programming completed in 7 min 2.500 s
Total time for flashing process(boot+erase+write) was 28 min 2.047 s
Phone Type: RM-561 (Nokia 2700 classic)
SW Version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35337604280005-9
Product Code: 0579808
Battery voltage: 4837 mV, current: 26 mA
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353376042800059
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
