Kết quả 1 tới 10 của 12
    Thành viên chính thức budop's Avatar
    Mặc định N72 trắng màn hình treo máy
    log info lúc đầu
    MCU SW : V 05wk07v48.2 04-10-07 RM-180 (c) Nokia.
    APE Core:
    APE Var :
    Prd.Code: 0531541
    Bpr.Code: 0530940
    Prod.Sn : DQE715491
    HW Vers : 7004
    APE HW :
    APE Adsp:
    EM RETU : 32
    EM TAHVO: 53
    RFIC Ver: 150a160f
    DSP Vers: rolf_espresso_05wk07v29p1
    IMEI : 353089-02-102678-2
    SL Serv : SIMLOCK SERVER VERSION 58
    SL Conf : 244-07-00000000000
    SL Prof : 0000000000000000
    SL Count: 00 00
    BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    Provider: Nokia Test;Finland
    thấy thiếu áp APE e câu theo hình này
    xong e chạy flash lại như thế này
    1ST BOOT : C0,0C [Rm-180] [2.0.9.0]
    OMAP ID : 17100701
    OMAP MODE : 00
    OMAP PBID : 224EEA6373DC615341096E73ADD960B588345176
    OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B
    OMAP ROID : AB5E4ADB27A06946
    RAPx ID : 000000010000022600010006000C192101012200
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx PBID : 2150010D596568513994CC6DF7E9B88B0BBB9204
    RAPx MODE : 00
    RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14
    RAPx ROID : F28A211FCEA7B19D
    CMT 1ST Boot OK
    CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0
    CMT FLID0 : 00010002-00007111, Amd 29NS064J
    CMT FLCNT : 00000000000000000000000000000000000000
    CMT MCID0 : FFFF0000-00000000
    CMT 2ND Boot OK
    CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
    CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    IMAGE : RM180_50819401.C0
    CMT NOR Erase Area: 0x00000000-0052B6C1
    CMT NOR Erase Area: 0x006A0000-006BFFFF
    CMT NOR Erase Area: 0x006DF000-006EFFFF
    CMT NOR Erase Area: 0x00700000-007EFFFF
    CMT FLASH ERASE OK, Time: 00:44
    Written: 7 Certificate(s)
    CMT FLASH WRITE OK, Time: 00:27
    OMAP ID : 17100701
    OMAP MODE : 00
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx MODE : 00
    CMT 1ST Boot OK
    CMT 2ND Boot OK
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    APE 2ND Bt: helen3_2nd.fg, Ver: 1.35.0
    00000090: 00 00 ..
    ERR: APE 2ND Boot FLB1_MSG_C2: 00000400000000B172 APE 2ND CONF:
    kết quả là not ok! a nào có cao kiến vào chỉ dùm thằng em cái.thanks all
    V.I.P Chaunv.Mobile's Avatar
    Tiền Giang
    bạn flash lại xem, bị lổi rồi
    Học Học Nữa Học Mãi
    chaunv78@yahoo.com 0945.618.618
  3. ( Chaunv.Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    budop (14-08-2011)
    May 2011
    Hà Nội City
    Thay cáp khác chạy lại hoặc mang qua box khác xem thế nào đã bạn
  5. ( ĐẶNG BẢO_GSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    budop (14-08-2011)
    em chỉ có mỗi HWK thôi anh ơi! còn cách nào khác không mấy a
    May 2011
    Hà Nội City
    Bạn cạo lại chân cắm USB lấy cáp Zin kết nối thử nếu được
    thì bạn chạy lại bằng phoenix dead usb cho en nó phát xem
  8. ( ĐẶNG BẢO_GSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    budop (14-08-2011)
  9. #6
    Trích Được post bởi ĐẶNG BẢO_GSM™ Xem bài viết
    kg kết nối đc a ơi!
  10. #7
    May 2011
    Hà Nội City
    SAo lại không kết nối được?
    bạn vệ sinh lại tx cáp trên máy
    vì dòng này cáp khó nhận hơn những dòng mới bây giờ
    nhưng mình làm mấy e rùi vẫn ok
    khi chọn file xong bạn tháo pin lắp lại hoặc nhấp nhấp nút nguồn cho nó kết nối là ok mà
  11. #8
    V.I.P minh thai's Avatar
    Áp APE có rất nhiều cách để câu .
    Một cây máy nếu đã xác định mất áp APE thì chỉ cần câu đúng thì tự động máy sẻ lên nguồn kg cần phải chạy .
    Câu áp APE sai mà chạy lại vô tình rắc rối , sau khi đã chạy not ok có câu lại đúng đường thì chạy bao nhiêu lần máy cũng kg lên đc đâu .
    Bến Lức_Long An
    minhthai379
  12. ( minh thai ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    budop (14-08-2011)
  13. #9
    Trích Được post bởi minh thai Xem bài viết
    thanks vip
    tiếp theo em phải làm gì đây?
    vip cho e vài cách câu nữa để tham khảo đc kg ạh
  14. #10
    PHÚ ĐIỀN-TÂN PHÚ-ĐỒNG NAI
    anh hãy seard lại những cách câu mà ae đã đưa lên rồi sau đó khoan câu kéo gì cả mà anh hãy dựa theo hình mà xem áp rồi đo xem máy mình mất áp nào thì câu áp nấy mỗi máy mỗi khác đâu phải bệnh nào cũng giống nhau hãy đo dạc kĩ rồi câu nhé anh
  15. ( nhathuy_mobile2009 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    budop (15-08-2011)
  1. N70 trắng treo
    By minhquan1985 in forum BB5
    Trả lời: 30
    Bài viết cuối: 16-03-2012, 21:20
  2. N73 rớt đất.trắng màn hình-treo máy !
    By thanhnammobile07 in forum BB5
    Bài viết cuối: 13-11-2010, 20:46
  3. n72 trắng màn treo ko tắt được
    By minhtu2326 in forum BB5
    Bài viết cuối: 16-12-2009, 21:28
  4. N72 trắng màng hình và treo nữa.
    By quocvienlxag in forum BB5
    Trả lời: 32
    Bài viết cuối: 08-06-2009, 08:24
  5. n72 treo trắng màn hình
    By tan525 in forum BB5
    Bài viết cuối: 02-01-2009, 11:51
