Các bác giúp em con này với.
Backup already exists(C:\mobileEx\3.5\data\backup\XGOLD_RM-647_83EE19D0930FDAD0_IMEI.back)
MXKEY Serial: [FT SCR2000 0] - C0841030
Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0
Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921600
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing file: rm647_006.200
Downloading item CODE:hw_b2_rm647_r06.200.fls, num block: 3, size: 3.99 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 55.094 s
Erasing area 0x00C60000-0x00E4D5BE ...OK
Programming completed in 51.172 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.187 s
Checksum verified (0x2602)
Processing file: rm647_006.20ia
Downloading item CUST:hw_b2_rm647_006.20ia.fls, num block: 1, size: 1.28 MB
Erasing area 0x00210000-0x00355A3E ...OK
Programming completed in 33.344 s
Checksum verified (0xCCA3)
Processing file: rm6470_nai06.20ia
Downloading item CUST:hw_b2_rm6470_nai06.20ia.fls, num block: 1, size: 348.33 KB
Erasing area 0x00EB0000-0x00F0643E ...OK
Programming completed in 9.078 s
Checksum verified (0x7F11)
Total time for flashing process(boot+erase+write) was 3 min 58.641 s
Phone Type: RM-647
SW Version: V 06.20 01-12-10 RM-647 (c) Nokia
Imei plain: 35700104333818-2
Product Code: 0592248
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: IA
Language Pack:
English,Arabic,Farsi,French,Urdu
Imei net: 35700104333818
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
			 1280 Flash ok không lên nguồn
			 Được post bởi luongno
