Kết quả 1 tới 10 của 16
    Thành viên chính thức thanhchien_mobi179's Avatar
    Dec 2009
    Mặc định tập tò chạy mxkey cần mấy anh chỉ dẫn giúp
    nhưng tiêu đề đã nói .em vừa mua mxkey về ko biết chay nhưng thế nào.lay máy 1208 ra tập chạy .em flash lại thử thi máy lên conte.moi ngươi chỉ em chạy với.sư phụ ở xa wa.mong đưMXKEY Serial: [FT SCR2000 0] - C083AD4E
    Using device: POTATO BOX, FW ver: 01.B1
    Driver: FTDIBUS, ver: 2.0.0.0, NTMP ver: 2.0.0.1
    Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011)
    ASIC ID: 0x2292 [UPPCosto ver: 1.3]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
    UEM ID: 00AFC6EFA3BDA66
    ASIC type: 11
    UEM Imei: 35602803289946
    Flash Imei: 35602803289946
    RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35602803289946_BA CK.rpl"
    Processing MCU file: rh105_05.910
    [DCT4,DCT4 ALGORITHM] size: 2.28 MB
    Supported Ids: 2292
    UEM ID: 00AFC6EF:2984DA60
    Area [01000000-0100FFFF] erased in 0.359 s
    Area [01010000-013AFFFF] erased in 20.219 s
    Area [013B0000-013EFFFF] erased in 1.453 s
    Area [017C0000-017EFFFF] erased in 0.063 s
    Area [01FC0000-01FEFFFF] erased in 0.047 s
    Flash programming ...
    Programming completed in 16.344 s
    File Processed in 53.969 s
    Processing CNT file: rh1050_nai5.91mr
    [DCT4,DCT4 ALGORITHM] size: 139.53 KB
    Supported Ids: 2292
    Area [01380000-013AFFFF] erased in 1.078 s
    Programming completed in 1.015 s
    Content extract fail, continue anyway ...
    File Processed in 46.516 s
    Processing PPM file: rh105_05.91mr
    [DCT4,DCT4 ALGORITHM] size: 1.20 MB
    Supported Ids: 2292
    Area [01240000-0124FFFF] erased in 0.359 s
    Area [01250000-0137FFFF] erased in 6.719 s
    Programming completed in 8.625 s
    File Processed in 31.141 s
    Total time for flashing process(boot+erase+write) was 2 min 11.672 s
    Phone not responding !ơc sư giúp đo của các anh.
    Dec 2009
    tiếp theo em phải làm nhưng thế nào nữa.cảm ơn mọi người trước
    V.I.P ThanhHai_GSM's Avatar
    che chân số 6 (vpp) dưới main chạy lại đi
  4. ( ThanhHai_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    thanhchien_mobi179 (20-08-2011)
    Dec 2009
    Trích Được post bởi ThanhHai_GSM Xem bài viết
    chân đó là chân nào vậy anh.chỉ em với
    V.I.P Chaunv.Mobile's Avatar
    Tiền Giang
    đồng bộ cho nó 1 phát nữa nha
    Học Học Nữa Học Mãi
    chaunv78@yahoo.com 0945.618.618
  7. ( Chaunv.Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  8. #6
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    kiểm tra lại cáp đi bạn,chạy phải báo done thì mới unlock được
  9. ( thuyet_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  10. #7
    Thành viên mới huynhphong85's Avatar
    May 2011
    Trích Được post bởi thanhchien_mobi179 Xem bài viết
    ASIC type: 11
    Supported Ids: 2292
    Supported Ids: 2292
    Supported Ids: 2292
    bước cuối cùng máy không vào được loawmodel nên không đồng bộ được.anh lấy cáp đa năng múc ok
  11. ( huynhphong85 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  12. #8
    Dec 2009
    Trích Được post bởi huynhphong85 Xem bài viết
    em đang chạy bằng cáp đa năng mà
  13. #9
    V.I.P minh thai's Avatar
    Chà rửa cái main cho sạch gở bõ mấy cái tụ sau chấu bin vẩn not ok thì lấy cáp lưng ra chạy . DCT4 chạy cáp lưng ok hơn
    Bến Lức_Long An
    minhthai379
  14. ( minh thai ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  15. #10
    Dec 2009
    Trích Được post bởi minh thai Xem bài viết
    Chà rửa cái main cho sạch gở bõ mấy cái tụ sau chấu bin vẩn not ok thì lấy cáp lưng ra chạy . DCT chạy cáp lưng ok hơn
    cảm ơn anh.máy em vẫn dùng bình thường.do em mới mua mxkey nên lấy chạy thử ,và bị conte.em bỏ vào jaf chạy ok.nhưng em mun học them về cach chạy mxkey.cảm ơn ah mong ah giúp
  1. Xin giúp chạy USB Mxkey
    By qngoc in forum BB5
    Bài viết cuối: 27-08-2013, 19:50
  2. Xin giúp chọn file E63 chạy bằng Mxkey!
    By thesmile555 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 07-08-2013, 17:44
  3. Trả lời: 18
    Bài viết cuối: 13-08-2011, 12:02
  4. Mxkey chạy báo lổi mong được giúp đở
    By hoaitrinh in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 15-09-2009, 22:42
  5. Xin giúp mxkey chạy 6280
    Bài viết cuối: 13-08-2009, 17:55
