Kết quả 1 tới 10 của 15
    Thành viên chính thức transinco1_5's Avatar
    May 2007
    Mặc định 1650 nhờ các bac giúp
    con 1650 của e bi tai nghe , e thay nguồn ( nguồn máy bt) giờ dùng một lúc ( khoang 4 phút) la mất nguồn . đây la log của e nóGetting MCU ID
    MCU ID: 0x2292
    FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 6.00
    30-09-09
    RM-305
    (c) NMP
    HW version:
    PCI version:
    UEM version: 1328
    UPP version: 8850
    RFIC version: 0700
    DSP version: ICPR62_08w31_UPP
    LCD version: SDI:GUINv93
    S6B33D1
    PPM version: V 6.00
    30-09-09
    RM-305
    (c) NMP
    MQ
    ADSP SW version: V 6.00\n30-09-09\nRM-305\n(c) NMP\nmq
    Production serial number:
    Product code:
    Module code:
    Basic production code:
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 354197032782423
    IMEI spare to net: 3A 45 91 07 23 87 42 02
    IMEI SV to net: 33 45 91 07 23 87 42 72 F2
    Master Code: 1747434703
    Phone type: RM-305, Software version: 6.00, Language Pack: MQ
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-305.ini
    Setting local mode...
    Reading product code...
    Product Code:
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-305\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-305\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.910
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.91mc
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm3050_nai5.91mc
    Languages in ppm: English,Thailand
    Done!
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    bệnh hiện tai nghe có thể vệ sinh chân xạc hoặc remove mấy con tụ nằm trên đg tai nghe cạnh chân xạc là ok. nhưng như bạn nói đã dính tai nghe lại còn 4p mất nguồn mình nghỉ 80% bị vào cpu
    May 2007
    ko lúc đầu máy bình thường chỉ bị tai nghe thôi ,mình làm hết mọi cách ko đc mới thay uem , giờ hết hiên tai nghe , nhung dùng đc 1 lúc là mất , mình đã xóa chay lại rồi mà vẫn ko đc
    PHÚ ĐIỀN-TÂN PHÚ-ĐỒNG NAI
    vậy là đung rồi anh thay nguồn rồi phải write RPL cho nó +unlock +factory nữa là ok ,box ime và asic lên anh em gửi rpl cho
    Dec 2009
    GIALAI
    máy nó chưa có PM full và Imei chưa chùng kìa. witer cái imei ban đầu lại rồi nạp pm full là OK.
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    write cái pm full.ngôn ngữ cũng chưa có TV nạp lại đi pồ
    May 2011
    Hà Nội City
    đầu tiên chỉ bị tai nghe mà làm nguồn sớm vậy
    bị tai nghe mình do nguồn chạm phần tai nghe nhưng không cần phải nhấc nguồn đâu câu lại là ok
    còn bây giờ bạn làm nguồn bị vậy thì wr lại đi
    Thành viên chính thức bonmobile89's Avatar
    Dec 2010
    xóa full nạp lại .wirte pm . unlock . factory cho nó phát xem sao bác
    Thành viên tích cực nguyennghi's Avatar
    Aug 2010
    Trích Được post bởi GIALAI_GSM Xem bài viết
    chuẩn nè múc ngay
    Vi phạm nội quy cps2010's Avatar
    Aug 2010
    Mặc định tuananh_mobile1990
    thay lại con nguồn khác đi anh nạp lock lại không được hay thay upp
  1. xin ae xem giúp log 1650
    By tran_ba in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 03-01-2011, 09:11
  2. MobiMB v3.5.3.9 Reloaded (Unofficial) for Nokia 1200, 1202/03, 1650, 1650, 1661
    By TUYHOAGSM™ in forum Chương trình cài hình nhạc cho các lọai ĐTDĐ
    Bài viết cuối: 27-10-2010, 09:37
  3. 1650 cần anh em pro giúp đở
    By cuong phone in forum DCT4 - WD2
    Trả lời: 18
    Bài viết cuối: 26-03-2010, 19:33
  4. 1650 cần ae giúp....
    By chanhtin_2104 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 30-07-2009, 21:47
  5. 1650 giúp em con này với
    By vanquang in forum DCT4 - WD2
    Trả lời: 15
    Bài viết cuối: 30-09-2008, 19:43
