    Thành viên chính thức truyenpro0404's Avatar
    May 2011
    Mặc định 3120 cần giúp
    em nó lúc có sóng lúc không
    Getting MCU ID
    MCU ID: 0x2142
    FLASH ID0: 277E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Failed! Aborting!
    Reading...
    MCU SW version: V 06.31
    25-11-05
    RH-19
    (c) Nokia.
    HW version: 4835
    PCI version:
    UEM version: 1092
    UPP version: 8514
    RFIC version: 0300
    DSP version: N5.20
    LCD version: LDS172
    PPM version: V 06.31
    25-11-05
    RH-19
    (c) Nok
    T
    Production serial number: DCE278280
    Product code: 0516553
    Module code: 0202205
    Basic production code: 0513172
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO: h?????????????????????????????????????????????????
    Default SN type: h?????????????????????????????????????????????????
    IMEI plain: 357088007968708
    IMEI spare to net: 3A 75 80 08 70 69 78 00
    IMEI SV to net: 33 75 80 08 70 69 78 10 F1
    PDC: 4E 54 54 4A 50 12 34 56
    Master Code: 5545754546
    Phone type: RH-19, Software version: 06.31 , Language Pack: T
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-19.ini
    Setting local mode...
    Reading product code...
    Product Code: 0516553
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-19\
    Scanning for ini files...
    Done!
    nhờ pro nào xem dùm với
    Trung tâm TM-DV viễn thông tin học AT
    Yahoo: atcomputerqn
    Thành viên tích cực dung-dt68's Avatar
    Jun 2011
    cho nó cái pm xem sao bạn
    May 2011
    hic tìm mà không có pm bạn ơi
    Yahoo: atcomputerqn
    V.I.P ThanhHai_GSM's Avatar
    lúc có sóng lúc không cho ic nguôn viên lắc
    ĐÔ LƯƠNG _ NGHỆ AN
    nếu cần file Pm thì qua y/m mình send cho ngại up quá
    Thành viên chính thức vthanh83's Avatar
    Oct 2010
    Ho Chi Minh
    dòng này thì làm lại ic nguồn thôi.
  1. 3120 cần giúp
    By ola17042 in forum DCT4 - WD2
    Bài viết cuối: 07-09-2011, 11:25
  2. 3120 cần giúp
    By mainhancon in forum DCT4 - WD2
    Bài viết cuối: 03-12-2010, 21:18
  3. Nhờ máy anh giúp em cây 3120
    By hocnghe in forum DCT4 - WD2
    Bài viết cuối: 16-03-2008, 20:16
  4. 3120 anh em giúp với
    By tuanhuong_lucky in forum DCT4 - WD2
    Bài viết cuối: 14-03-2008, 00:10
  5. 3120 ime ???/??? giúp với
    By deptraixudua in forum Ứng dụng dành cho Nokia
    Bài viết cuối: 18-10-2007, 15:36
