Chào các bác, tôi có con 6100, khi chay flash được 1 lúc thì báo :
MXKEY Serial: [FT SCR2000 0] - C0839ADE
Using device: POTATO BOX, FW ver: 01.B4
Connection status: UHCI:HUB:USB 1.10 (Full-speed)
Driver: FTDIBUS, ver: 2.0.0.0 , NTMP ver: 2.0.0.1
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Processing MCU file: npl2__05.800
[DCT4,DCT4 ALGORITHM] size: 5.18 MB
Supported Ids: 0120, 1120
ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
ExtBUSC: 2C34 B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
UEM ID: 00906361:C421DA60
Area [01000000-0100FFFF] erased in 0.562 s
Area [01010000-0157FFFF] erased in 48.750 s
Area [016B0000-017EFFFF] erased in 11.282 s
Area [01EB0000-01FEFFFF] erased in 1.079 s
Flash programming ...
Overlapped I/O operation is in progress
Error while programming [14] at 0x01080000, Result: 000D
flashing terminated !
Task failed at (08000025)!!!
Last RX buffer: 00 0D 09 4F A9 0A 01 0B 00 4C 0B 00 04 09 0B 00 0B 00 04 09
Nhờ các bác giúp đỡ !
			 6100 cần giúp đỡ
 6100 cần giúp đỡ
