Version from phone: 09.97
Version from file: 09.97
MXKEY Serial: [FT SCR2000 0] - C0849028
Driver: uhci:hub:hub:UFS2XX, ver: 3.6.0.0 , NTMP ver: 2.6.0.0
Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011)
Reading Important data ...
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35826203472368_BA CK.rpl).
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0D000217F42C685095F805C728EE8199595BDD1D
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
Storage0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
TransmissionMode: DDR&TX2
Processing MCU file: rm561__09.97.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [00140000-0137FFFF]
CMT FLASH,NOR area [01380000-0151FFFF]
erased in 1 min 34.593 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 2 min 29.672 s
Processing PPM file: rm561__09.97.ppm_v
[BB5,BB5 ALGORITHM] size: 6.90 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF]
erased in 34.906 s
Programming completed in 51.625 s
Processing CNT file: rm561__09.97.image_v_red_128
[BB5,BB5 ALGORITHM] page size: 128 K size: 13.70 MB
UCP page size is 128 K.
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF]
CMT FLASH,NOR area [02160000-03FBFFFF]
erased in 1 min 58.360 s
Programming completed in 1 min 42.047 s
Total time for flashing process(boot+erase+write) was 9 min 22.407 s
Phone Type: RM-561 (Nokia 2700 classic)
SW Version: V 09.97 18-06-10 RM-561 (c) Nokia
Imei plain: 35826203472368-8
Product Code: 0581057
Battery voltage: 4860 mV, current: 62 mA
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358262034723688
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN máy chạy song có dòng đỏ này em không biết nó lỗi j?Avoid SW Downgrade & manual erase to this phone !
			 các bac co kinh nghiệm phần mềm giúp em con 2700c này vỏi
