Kết quả 1 tới 10 của 13
    Thành viên tích cực bomnokia's Avatar
    Aug 2010
    Mặc định 2700c chạy xong 3 file không lên nguồn xin giúp
    máy em thay plash read rpl full rùi . chạy lại 3 file veser 9.98 xong nhưng ko vào được local mode . đây là log của em nó . các bác xem rùi giúp em với ạk ? em cám ơn trước .
    MXKEY Serial: [FT SCR2000 0] - C0845DFF
    Driver: UFS2XX, ver: 2.0.0.0, NTMP ver: 2.0.0.1
    Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
    Processing MCU file: rm561__09.98.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 0E400111638E8C56C3253D8F6CFE40643AC85B00
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
    TransmissionMode: 16Bit
    TransmissionMode: DDR&TX2
    Erase size: 21 MB
    CMT NOR area [00000000-000006BF] erased in 0.921 s
    CMT NOR area [000006C0-0001FFFF] erased in 0.141 s
    CMT NOR area [00040000-000BFFFF] erased in 3.406 s
    CMT NOR area [000C0000-0013FFFF] erased in 0.203 s
    CMT NOR area [00140000-0137FFFF] erased in 1 min 51.547 s
    CMT NOR area [01380000-0151FFFF] erased in 10.516 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100303130 (RAP Certificate 202 v.1) sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Programming completed in 2 min 26.578 s
    Processing PPM file: rm561__09.98.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.90 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 8.62 MB
    CMT NOR area [01520000-01DBFFFF] erased in 44.016 s
    Programming completed in 49.844 s
    Processing CNT file: rm561__09.98.image_v_blac
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 34 MB
    CMT NOR area [01DC0000-0215FFFF] erased in 25.875 s
    CMT NOR area [02160000-03FBFFFF] erased in 1 min 38.375 s
    Programming completed in 1 min 37.235 s
    Total time for flashing process(boot+erase+write) was 11 min 21.438 s
    Phone not responding !
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    xóa đi chạy lại bạn,ko được kiếm con flash khác,bình thường thay flash gì vào máy cũng khởi động được luôn nếu flash sống
  3. ( thuyet_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    bomnokia (08-09-2011)
    Thành viên chính thức nnam's Avatar
    Jan 2007
    Cambodia
    Anh thử đem qua box khác flash lại cái, thằng mx-key chạy cà tưng lắm! Tốt nhất hãy làm lại sw rồi sau đó hãy nghĩ tới hw
    Chuyên: Mua bán trao đổi phế liệu, đồ nhôm sắt.... Đặc biệt rượu nếp Long An và bia Sài Gòn đỏ
    2700c nếu thay thì thay cặp luôn đi bạn hiền ơi. goog luck
    Jan 2009
    Hải Phòng
    giống cái log 3110c của mình hôm wa, có gì ưa đây tham khảo nè bạn:
    http://saigonmobile.vn/forum/bb5/113...n-cap-cuu.html
    Thành viên chính thức canhlamdl's Avatar
    có gì liên hệ số điện thoai 0918.095.585 mình để lại cho cặp 2700 mình ở HCM
    Buôn Ma Thuột City.
    Cái này xóa full chạy lại chứ cần gì phải thay cặp, nếu flash còn ok
    : 0934.80.22.28 .
  9. #8
    Thành viên chính thức trimobile09's Avatar
    phuong nam
    thay cập rồi bạn
    doipinktrimobile09foreverhenkiepsauyou
  10. #9
    V.I.P Chaunv.Mobile's Avatar
    Tiền Giang
    Trích Được post bởi trimobile09 Xem bài viết
    thay cập rồi bạn
    óc, máy như vầy mà thay cặp thì phí quá
    Học Học Nữa Học Mãi
    chaunv78@yahoo.com 0945.618.618
  11. #10
    May 2011
    Hà Nội City
    Chủ thread lượm lúa rùi
  1. x1-01 chạy pm xong ko lên nguồn
    By toiyeuquehuongtoi in forum DCT4 - WD2
    Bài viết cuối: 09-07-2014, 05:37
  2. Trả lời: 1
    Bài viết cuối: 07-03-2014, 16:32
  3. ae giup 2700c lên nokia trắng un!e cần file để chạy phoenix
    By abc020010 in forum Phần mềm và các mã lệnh cho Nokia
    Trả lời: 21
    Bài viết cuối: 24-08-2012, 18:54
  4. Trả lời: 4
    Bài viết cuối: 31-01-2011, 20:15
  5. N6020 chạy xong không lên nguồn hepll
    By tranvantinh in forum DCT4 - WD2
    Bài viết cuối: 02-01-2009, 09:26
