Kết quả 1 tới 10 của 11
    Thành viên chính thức bacninhgsm's Avatar
    Mặc định Log 3110c cần giúp !
    MXKEY Serial: [FT SCR2000 0] - C0850EA4
    Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0
    Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011)
    Processing MCU file: rm237__07.30.mcusw
    [BB5,BB5 ALGORITHM] size: 14.49 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 29F001059D426F563473EB4ECC1D5587D7A75D77
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    FlashID0: 0020 881C - 0000 6A21 [ST M58LR256JU,256 Mbits] type: NOR,CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT NOR area [00000000-000006BF] erased in 0.640 s
    CMT NOR area [000006C0-0001FFFF] erased in 0.156 s
    CMT NOR area [00020000-0007FFFF] erased in 1.532 s
    CMT NOR area [00080000-000DFFFF] erased in 0.188 s
    CMT NOR area [00100000-001FFFFF] erased in 0.328 s
    CMT NOR area [00200000-0031FFFF] erased in 4.734 s
    CMT NOR area [00320000-0105FFFF] erased in 49.328 s
    CMT NOR area [01060000-01067FFF] erased in 0.657 s
    CMT NOR area [01068000-0107FFFF] erased in 0.156 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: C0E691EA16A7593A9BB28832D7312A39F7ED668D (RAP Certificate 66 v2) sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    Programming completed in 2 min 2.766 s
    Processing PPM file: rm237__07.30.ppm_c
    [BB5,BB5 ALGORITHM] size: 4.35 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 4.62 MB
    CMT NOR area [01080000-0151FFFF] erased in 17.547 s
    Programming completed in 37.203 s
    Processing CNT file: rm237__07.30.image_c_tr_128
    [BB5,BB5 ALGORITHM] page size: 64 K size: 4.69 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 10.75 MB
    CMT NOR area [01520000-01FDFFFF] erased in 34.000 s
    UCP page size is 128 K.
    Programming completed in 39.390 s
    Total time for flashing process(boot+erase+write) was 5 min 57.734 s
    ( Flash xong máy không lên nguồn . Mong ae giúp mình với )
    Anh Trường Mobile . Cựu Tự - Ngọc Xá - Quế Võ - Bắc Ninh ! Mobile : 0986 68 68 68
    Oct 2009
    tân phú-đồng nai
    nhìn log ok mà bạn,máy lúc đầu thế nào bạn.giờ ko lên nguồn nhưng dao động thế nào.bus check rùi paste cai log ae xem coi sao nhé.
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    nhìn log này mới thấy flash xong thôi mà anh đã thấy đồng bộ được đâu.anh check cái log lên để AE coi cho rõ
    ps;flash lại thì nâng ver nó lên cao ngút trời vào coi đã
    Trích Được post bởi tlpmobile_tk Xem bài viết
    Mình đã nâng ver rồi nhưng chạy vẫn không đồng bộ được .
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Original Imei: 35308102179366
    Original Product code: 0514949
    Bluetooth ID: 001F5CCF0EA5
    Phone not responding !
    tình trang máy lúc đầu thế nào bác
    V.I.P PhươngNamMobile's Avatar
    backup ok mà thì thay flash là ok.
    Đã test rùi.
    Hãy kích thank để cám ơn người giúp mình.
    không nên spam"thank".
    Jan 2009
    Hải Phòng
    cái này dùng phonenix đập phát chết luôn, mình mơé test ok ôn 3110c hôm trước
    Thành viên chính thức langtutimhoa_tlphaibiet's Avatar
    Apr 2011
    kiểm tra nút nguồn đi anh ơi
    yahoo:cu_tit_online
    ĐC:huyện sông mã-tỉnh sơn la
    korea
    chạy dead usb flast lại ver 7.30 không dc làm lại flast ok .thân
    TP Hồ Chí Minh
    Trích Được post bởi langtutimhoa_tlphaibiet Xem bài viết
    máy kg đồng bộ đc mà nút nguồn gì anh.
    flash V cao nhất not ok làm chân đóng lại hoặc thay mới flash.
  1. 3110c xin đc chỉ giúp
    By minhtinhmobile in forum BB5
    Bài viết cuối: 07-12-2012, 21:22
  2. xin giúp 3110c mất chân ic phím
    By dungsm in forum BB5
    Bài viết cuối: 10-11-2012, 16:46
  3. cần ae giúp gấp cây 3110c
    By NGỌC HÒA_GSM in forum BB5
    Bài viết cuối: 24-09-2012, 15:44
  4. cứu MIC 3110c anh em giúp em với
    By ngtuanthanh in forum BB5
    Bài viết cuối: 30-03-2012, 08:22
  5. xin giúp câu PA 3110C
    By giaphu_dn in forum BB5
    Bài viết cuối: 14-03-2011, 11:06
