MXKEY Serial: [FT SCR2000 0] - C0845AC3
Connection status: UHCI:HUB:HUB:USB 1.10 (Full-speed)
Driver: UFS2XX, ver: 2.0.0.0 , NTMP ver: 2.0.0.1
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000352
PUBLIC ID: 1D900202CA4000585A8CDFF210CC29DCA2243FDD
ASIC MODE ID: 00
ROM ID: 191EC665DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
eBB5ProtocolType: OLD
Storage0: 00EC 22FE - 0000 6921 [Samsung K8S5615ETA,256 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF
TransmissionMode: 16Bit
TransmissionMode: DDR&TX2
Processing MCU file: rm146__07.20.mcusw
[BB5,BB5 ALGORITHM] size: 14.56 MB
Supported Ids: 0103192101001101, 010C192101001101
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00020000-0007FFFF]
CMT FLASH,NOR area [00080000-000DFFFF]
CMT FLASH,NOR area [00100000-001FFFFF]
CMT FLASH,NOR area [00200000-0031FFFF]
CMT FLASH,NOR area [00320000-0105FFFF]
CMT FLASH,NOR area [01060000-01067FFF]
CMT FLASH,NOR area [01068000-0107FFFF]
erased in 4.875 s
Prog.status for Asic CMT ...
NOR: Success
Flash programming ...
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00020000, Result: 0010
Total time for flashing process(boot+erase+write) was 13.500 s
đó là log em chạy bằng mxkey
biết là lỗi ở chổ đỏ đỏ nhưng mà không biết xử lý thế nào, không biết có phải là do hw (con flash ) hay không?. mong anh em giúp với. Thanks
: 0934.80.22.28 . Gmail :
