card found: S/N xxxxxxxxxx
registered to: nguyenqngai
Connect phone on selected interface...
Core version : 1.29  Rev : 1.0
Selected FlashSettings : FullFlash
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm709__08.70.mcusw
PPM : rm709__08.70.ppm_t
CNT : rm709__08.70_003.image_t_ctv_ph_9g4b0
APE : rm709__08.70_sd_empty.fpsimage
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
Connection opened successfully
Waiting for communication response...
[BB5 FLASH]: Bootrom Ok!
ASIC ID:       000000000000000022000509200C0000
CPU ID :       BroadCom 21351 , Features : Dead-Test, USBCRT, FullUSB
EM0 ID:        00005361
PUBLIC ID:     0000000000DF55A2A03B4AE20BD84F6D22EC806A
ASIC MODE ID:  00
ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
ROM ID:        DE56D582BDDE7A3A
Use BCM21351_usb2nd.fg  ,  Rev : 2.1  Ver : 11.24.0
Processing RAWLOADER...
FLIC : 00300020
Req : XSR 1.6
Use BCM21351_XSR16_usbalg.fg  ,  Rev : 2.1  Ver : 11.24.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:09
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL: Check mode
ADL: phone is in flash mode
Backup enabled, will read all certificates...
Reading NPC certificate...
Reading CCC certificate...
Reading HWC certificate...
Reading R&D certificate...
Reading VARIANT certificate...
Reading PARTNERC certificate...
Reading MDM_KEYS certificate...
 - > No any CRT data (MCU damaged/CERT erased), skip saving
   ===Flashing [MCU]===
Erase : Processing rm709__08.70.mcusw
Partitioning....
Partitioning error! Phone Not respond!
Elapsed: 00:00:15
Check files done...
EM0 ID:        00005361
ASIC MODE ID:  00
FLIC : 00300020
Req : XSR 1.6
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:04
Waiting for response: 28
Waiting for response: 27
Waiting for response: 26
Waiting for response: 25
-------BOOT BREAKED BY USER-------
Phone not found...
Elapsed: 00:00:00
Check files done...
EM0 ID:        00005361
ASIC MODE ID:  00
FLIC : 00300020
Req : XSR 1.6
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:01
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : 37955B6FC432998EF0DB240E332228384D19ED09
IMEI : 358615041331284
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\358615041331284_CR  T_2nd.rpl
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing rm709__08.70.mcusw
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [ADA]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [RAP3NAND]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [MCUSW]
CMT: Writing Hash CERT [MCUSW1]
CMT: Writing Hash CERT [GENIO_INIT]
CMT: Writing Hash CERT [ISA+DYNSW]
Total writen 504 blocks
TIME : Write time : 00:00:30
MCU Write done
ADL: Request programm status
NAND status : 00000000 / 00000000 / 00000000
   ===Flashing [PPM]===
Erase : Processing rm709__08.70.ppm_t
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm709__08.70.ppm_t
Total writen 125 blocks
TIME : Write time : 00:00:07
PPM Write done
   ===Flashing [CNT]===
Erase : Processing rm709__08.70_003.image_t_ctv_ph_9g4b0
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:01
Write : Processing rm709__08.70_003.image_t_ctv_ph_9g4b0
Total writen 531 blocks
TIME : Write time : 00:00:33
CNT Write done
   ===Flashing [APE]===
Erase : Processing rm709__08.70_sd_empty.fpsimage
Partitioning eMMC area....
Partitioning Ok...
Erase : No any region, skip erase
Write : Processing rm709__08.70_sd_empty.fpsimage
Write error : Connection lost => HW error or Cable problem...
Write CMT failed on block 0
Elapsed: 00:07:35
Phone found!
Series 40 Device detected!
read info...  - Ok
Phone disconected!
