em nhân máy 2690 lên contacsevit đã wa tay thợ làm.em check = mx thì ra log vây.MXKEY Serial: [MxKey HTI FLASHER INTERFACE 1] - C0855BFC
Using device: HTI BOX, FW ver: 00.07
Driver: HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 04B0010DB97854505B9835B9AE17F59F20A5CF14
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
eBB5ProtocolType: OLD
Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: C6B9354E81AC464DED33FC7B90295086150F4539
TransmissionMode: DDR&TX2
Original Imei: 35377704559831
Original Product code: 0592103
Bluetooth ID: D4CBAFD360F8
Phone type: RM-635 (Nokia 2690)
SW version: V 10.10 22-04-10 RM-635 (c) Nokia
Imei plain: 35377704559831-1
Product code: 0591640
Battery voltage: 4728 mV, current: 146 mA
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 353777045598311
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
em đã bakup rpl.pm full.xóa flas chay lai.nap rpl.pm full/repai lai nhưng ko hết.ae giúp em/SECURITY_TEST failed! lỗi chỗ này ne ae
			 2690 contacsevit xin giúp
