e nhận của khách con x1-01 rơi nc đã qua thợ khác làm cpu e làm lại nhưng ko đc. mà cặp cpu và Flash còn này hàng hot nên chưa có e thay thử cặp của 1280 vào chạy ok nhưng ko đồng bộ đc pots lên cùng anh em thảo luận và cho em ý kiến
LOG CỦA EM NÓ ĐÂY
MXKEY Serial: [FT SCR2000 0] - C0843E1B
Connection status: UHCI:HUB:HUB:USB 1.10 (Full-speed)
Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.24
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbps
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing file: rm713_005.290
Downloading item CODE:hw_b1_rm713_r05.290.fls, num block: 3, size: 5.58 MB
Erasing area 0x00000000-0x00005FFE ...OK
Programming completed in 0.593 s
Erasing area 0x00800000-0x00BEFFFE ...OK
Programming completed in 1 min 7.125 s
Erasing area 0x00C5D000-0x00DFB6FE ...OK
Programming completed in 27.766 s
Checksum verified (0xF194)
Processing file: rm713_005.29mr
Downloading item CUST:hw_b1_rm713_005.29mr.fls, num block: 1, size: 5.07 MB
Erasing area 0x00100000-0x0061113E ...OK
Programming completed in 1 min 26.031 s
Checksum verified (0xBD22)
Processing file: rm7130_nai05.29mr
Downloading item CUST:hw_b1_rm7130_nai05.29mr.fls, num block: 1, size: 699.14 KB
Erasing area 0x00E60000-0x00F0DF7E ...OK
Programming completed in 11.813 s
Checksum verified (0xC9A1)
Total time for flashing process(boot+erase+write) was 5 min 53.703 s
