ae giúp mình phát 6280 lúc nhận bị contac flash lại bị hạn chế điện thoại
đã backup rpl và pm thank ae trước
còn đây là log của nó
MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 1] - C0859FE9
Using device: HTI BOX, FW ver: 00.17
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Reading Important data ...
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35792600510904_BA CK.rpl).
Processing PPM file: rm783006.43.ppm_v
[BB5,BB5 ALGORITHM] size: 4.81 MB
Supported Ids: 0103192101003000, 010C192101003000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000232
EM1 ID: 00000352
PUBLIC ID: 17A00203D5810054D6F4EAFA2BE2CE84A38C7CD9
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
eBB5ProtocolType: OLD
Storage0: 00EC 22FE - 0000 0121 [Samsung K8S5615ETA,256 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: EA424306455C103E3853B304DD1BC0E10F839FBC
TransmissionMode: DDR&TX2
Erase size: 5 MB
CMT FLASH,NOR area [011E0000-016DFFFF]
erased in 32.110 s
Prog.status for Asic CMT ...
NOR: Success
Flash programming ...
NOR: Success
Programming completed in 32.110 s
Processing CNT file: rm7830006.43.image_v
[BB5,BB5 ALGORITHM] page size: 64 K size: 3.19 MB
NOR page size in the phone is 64 K.
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000352
ASIC MODE ID: 00
Erase size: 9 MB
CMT FLASH,NOR area [016E0000-01FDFFFF]
erased in 58.766 s
NOR: Success
NOR: Success
Programming completed in 21.469 s
Total time for flashing process(boot+erase+write) was 3 min 8.656 s
Phone type: RM-78 (Nokia 6280)
SW version: V 06.43 30-03-07 RM-78 (c) Nokia
Imei plain: 35792600510904-1
Product code: 0534373
Battery voltage: 4660 mV, current: 44 mA
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 357926005109041
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
