nhận cây 6700c mất nguồn đem Flash bằng Mx USB báo lổi vậy là sao ạ
MXKEY Serial: [FT SCR2000 0] - C0801465
Driver: NMWCD, ver: 7.1.32.65
Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011)
Processing MCU file: rm470__13.21.mcusw
[BB5,XSR 1.6] size: 25.21 MB
Supported Ids: 6003192102021104, 600C192102021104, 6003192102011104, 600C192102011104, 0400000200000000
Waiting for USB device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 58DF53D
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001030
CMT PUBLIC ID: 20A00005F95E0344F16F306D9E987A46DC97078B
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
CMT ROM ID: 3E273BF637BE26FA
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
Secondary boot loaded.
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
FUR: Adding Asic CMT as client OK.
Reading CMT HWC (0xD4 bytes).
Rpl(Certificate) backup already exist (D:\3.5\data\backup\BB5_35318103626649_CERT.rpl).
CMT PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6
Storing certificate [NPC, CCC, HWC, R&D] OK.
Partitioning....
Partitioning complete
Erase size: 43.81 MB
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-0009FFFF]
CMT FLASH,MuxOneNAND area [000A0000-0041FFFF]
CMT FLASH,MuxOneNAND area [00420000-0069FFFF]
CMT FLASH,MuxOneNAND area [006A0000-01F1FFFF]
CMT FLASH,MuxOneNAND area [02900000-02FBFFFF]
CMT FLASH,MuxOneNAND area [0F2C0000-0F8BFFFF]
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: CABA40E4 [RAP Certificate 145 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT LDSP block sent
CMT MCUSW block sent
CMT ISA+DYNSW block sent
Programming completed in 5.766 s
Processing PPM file: rm470__13.21.ppm_c
[BB5,XSR 1.6] size: 6.96 MB
Supported Ids: 6003192102021104, 600C192102021104, 6003192102011104, 600C192102011104, 0400030000000002, 000000A000000028
Erase size: 9.87 MB
CMT FLASH,MuxOneNAND area [01F20000-028FFFFF]
Programming completed in 1.500 s
Processing CNT file: rm470__13.21_006.image_c_ctv_de_94432
[BB5,XSR 1.6] size: 26.81 MB
Erase size: 195.06 MB
CMT FLASH,MuxOneNAND area [02FC0000-0F2BFFFF]
Programming completed in 4.328 s
Total time for flashing process(boot+erase+write) was 23.359 s
Phone not found, retrying ...
Phone not responding !
ae xem giúp với khách hối quá ạ
